Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-18-2009, 12:46 AM   #1
DRPSNERTLE
Member#: 131947
02&4 Forester & Baja
Blue Ridge Pearl& Silver
Default Moon roof problem
Here goes:
2004 Baja sport without any problems to date except having to replace gas, oil, tires, etc. Moonroof won't close with switch and seems operable with manual hex key provided. The tilt function operates as desired but, I cannot get the darn thing to close. Cables are intact, channels are clean, everything looks like the day I bought it and I have done searches on all the forums and haven't found a solution. I removed and cleaned the contacts on the switch, checked fuses, wire chafing etc. but nothing seems amiss. Has anybody experienced this malady? Please advise since spring is on the horizon.
DRPSNERTLE is offline   Reply With Quote
Old 02-19-2009, 06:34 AM   #2
jeromes
Member#: 192299
2011 Forester XT
Default Try this link on Scoobytruck
Try this link for the Baja Parts Diagram I provided to Scoobytruck. The Moonroof part section may point to something that could be giving you the problem. Hope it helps
http://scoobytruck.com/pdf/Baja_2003-2005.pdf
jeromes is offline   Reply With Quote
Old 02-21-2009, 12:12 AM   #3
DRPSNERTLE
Member#: 131947
Default Thanks!
Peaty at ScoobyMods reminded me about the PdfTown site and I was able check out the information on the Legacy Outback MY02 and I found the pin-outs diagram I needed for testing. Now armed with your information, I was able to verify the parts & pieces being the same and thanks to you, I even have part numbers!
Just my luck, the nice weather we were having Monday and Tuesday has changed so now I'll have to wait until another day.
Forester Moon roof not flush with roof 240c Service & Maintenance 0 10-03-2008 01:45 PM
Forester Moon roof not flush with roof 240c Forester Forum 0 09-27-2008 06:49 PM
02 WRX moon roof The_Triton Interior & Exterior Modification 96 09-19-2005 02:52 PM
moon roof. babyblue Tri-State Area Forum 12 06-08-2002 02:07 AM
US WRX has no moon roof and UK does- why? WReX_rated Newbies & FAQs 27 05-03-2002 11:08 AM
