Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 02-18-2009, 03:07 AM   #1
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Default But can you answer this...
So guys I am finalizing my swap and one big question just came up that I have no idea how to address... So quick run threw I am swapping a 2002-2003 interior and full drivetrain into my 1995 Legacy Wagon.
The question is what do I do about the locks, do I remove the locks from the WRX and place them in the Legacy, including the doors and rear hacket, or do I swap out the key holes in the steering columns? Does anyone know how to swap out the steering column key holes? My conundrum is driving me crazy some help would be awesome
Thanks
Josh
bugeye-brawler is offline   Reply With Quote
Old 02-18-2009, 09:41 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
use the old keys
new key cores won't fit in the doors
Old 02-18-2009, 12:57 PM   #3
bugeye-brawler
Member#: 182337
Sport -- White
what about the ignition use the old ignition key as well? and where would I find out how to switch them?
Old 02-18-2009, 01:07 PM   #4
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
use the old keys. or 2 keys if needed (you have a newer ignition, but the old door locks)
SubarusRmyThing is offline   Reply With Quote
Old 02-18-2009, 01:53 PM   #5
MasterKwan
Member#: 98961
2003 WRX
I'm going to be using the old keys for the doors and trunk and the immobilizer key for the ignition.
Old 02-20-2009, 12:25 PM   #6
bugeye-brawler
Member#: 182337
Sport -- White
I figure I will keep the Legacy locks on the doors and just use the key-less entry to open the doors (assuming I get it wired to work) and then the WRX ignition switch... I'll just keep the Legacy key just in case I can not get in
Thanks everyone
Old 02-21-2009, 01:56 PM   #7
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
The MY02/03 WRX doesn't have immobilizer so there is no reason to use anything other than the stock legacy ignition. One key doors and ignition.
yebokmj is offline   Reply With Quote
Old 02-21-2009, 06:34 PM   #8
bugeye-brawler
Member#: 182337
Sport -- White
Is there a place I can find out how to swap out the key holes I have not found anything anywher
Old 02-21-2009, 07:48 PM   #9
MasterKwan
Member#: 98961
2003 WRX
The ones in the doors? You could probably pull the door panel off and look and and see how it's done.
Old 02-23-2009, 03:19 AM   #10
StretchX20
Member#: 203803
new ignition old door locks !!!!
StretchX20 is offline   Reply With Quote
Old 02-23-2009, 01:08 PM   #11
bugeye-brawler
Member#: 182337
Sport -- White
No the one in the steering column.
I keep leaning that way... I really want that STI key and supposedly it won't fit in the Legacy
can you answer this Math Riddle cRay Off-Topic 16 12-15-2004 10:13 AM
can any of you answer this? hitman912 Proven Power Bragging 5 08-12-2003 06:14 PM
can you answer this..? Imprezive2002 Normally Aspirated Powertrain 2 08-10-2003 03:06 PM
Proven power?!! Can you answer this! WS6toWRX Proven Power Bragging 14 04-22-2003 06:19 PM
Can you answer this? n20x3whitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-29-2002 01:59 PM
