Old 02-18-2009, 03:36 PM   #1
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Default AMS V-band GT30R kit on a customer car....with prototype FMIC
One of our local customers (Nate) was one of the first people to receive our GT30R V-band turbo kit. The car did very well with just bolt ons and a top mount.
(Since this car is an 07 STI early on its life the #4 Piston went belly up so we had to put our stage 1 shortblock in it.)
In any event recently Nate decided to ditch the top mount in lieu of a true FMIC. Now we do not have an FMIC solution for the Subaru just yet but Nate really wanted us to try and make something custom for him as the entire car to this point was all AMS. Using a little bit of custom fabrication we were able to take our widely successful EVO core and adapt it to work with Nate's 07 STI. The car came out great and the power increase was pretty substantial.
Now this is not a true back to back test as Nate also decided to delete his TGV's in the process. But this dyno demonstrates pretty clearly how potent this turbo kit really is. All that was changed between the two runs was an AMS FMIC and TGV deletes.
Mod List for the first Run:
AMS Built Stage 1 shortblock
Stock heads and cams
AMS GT3076R Turbo kit .63 A/R exhaust housing
Perrin Top mount IC
Perrin equal length headers
Invidia 3" Catless exhaust
Walbro fuel pump
Deatschwerks 850cc injectors
Quarter master Twin disc clutch with push conversion
AMS open source ECU tune
Gas: 93 Octane
Boost: 23 psi
Parts added for the second run:
AMS prototype FMIC
AMS TGV Deletes
Gas: 93 octane
Boost: 23 psi
As you can see from the chart above this car picked up over 25 whp and 50 ft lbs of torque!!! This thing is an ANIMAL on the street and spools extremely quick
Here are some shot of Nate's car with the FMIC. We are planning on making a subaru FMIC kit but The production core will be a tad bit wider. Let us know what you think
Eric
AMS is offline   Reply With Quote
Old 02-18-2009, 03:39 PM   #2
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
nice numbers for 23psi.
BuggeyEYED is offline   Reply With Quote
Old 02-18-2009, 03:43 PM   #3
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
dang! nice numbers and the ams fmic looks real good , v-band is the way to go , clean build !
20wrx05 is offline   Reply With Quote
Old 02-18-2009, 03:53 PM   #4
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
Wow . . . The gains on Spool alone are reason enough !!
Great looking "rough" graph. . . gt30 shouldn't lose that much power in the upper end . . . :S
Fine tune that beast and you have one heck of a prototype ! !
Good Work from AMS once again
Scooby-King is offline   Reply With Quote
Old 02-18-2009, 03:58 PM   #5
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
The FMIC proto type looks clean as it is...why not just use that as your production core?
cellgeek101 is offline   Reply With Quote
Old 02-18-2009, 04:16 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
with the size of your fmic it should
have given you more than 25 whp & 50 ft-lbs..
but nice numbers and install..to bad the front bumper beam
had to go.
if a vendor would make a fmic that filled the entire lower bumper
opening & retain the factory bumper beam...
the proto-type is for an evo..
Old 02-18-2009, 04:20 PM   #7
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Pics are working....NM.
CoolRex is offline   Reply With Quote
Old 02-18-2009, 04:21 PM   #8
Jhovany
Member#: 137317
2006 STI
Rally Blue
AMS???? Never heard of 'em !!!!!! LOL great jobs guys.....I must admit....that FMIC looks like its size TINY!
Jhovany is offline   Reply With Quote
Old 02-18-2009, 04:23 PM   #9
remowgn
Member#: 41149
09 FXT
SSM
Because there's enough room in the subaru bumper to make it even bigger?
remowgn is offline   Reply With Quote
Old 02-18-2009, 04:30 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i think this is the 3rd one of these FMIC tests lately are exactly the opposite of what people always claim with FMIC's.
Wasnt the claim before that FMIC will
- add lag, thus decreasing the low end
- make significant gains at high rpm
i swear this is the 3rd FMIC vs TMIC test lately thats added a shiiite load of low end tq and nothing above 6k rpm.
Was there a retune of this car also? With more boost at higher rpm thats not shown above?
Old 02-18-2009, 04:37 PM   #11
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
yes it will its a .63
4ST-AIR is offline   Reply With Quote
Old 02-18-2009, 04:37 PM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
don't forget that the TGV's were removed also...
But I did notice also that there was not a loss in spool up..
Throttle response however I bet has taken a hit over the TMIC however... That doesn't show up on the dyno chart as you know.
jigga is offline   Reply With Quote
Old 02-18-2009, 04:46 PM   #13
AMS
Member#: 27854
STI, WRX, GTR, EVO,
I am sure the taper in power up top is due to many things like stock head, Stock cams, Stock intake manifold. I do think the biggest contributing factor is the small .63 A/R hotside
This FMIC core is far from tiny...its efficient. In fact it been proven to work on an EVO efficiently up to 600whp. after that we have a monster core we can put on the car.
I think the plans with the subaru are to extend each side a few inches but keep the core tall like it is now.
The current dimensions of this core pictured above are 12.4" tall, 20" wide (28" with end tanks) and 3.625" thick
Old 02-18-2009, 04:46 PM   #14
AMS
Member#: 27854
STI, WRX, GTR, EVO,
Oh and yes the car was retuned after the mods. We would never post up or do a full pull on a car that is not tuned.
Eric
Old 02-18-2009, 04:51 PM   #15
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I'd love to see this car with the .82 backhousing...
Nice to see some V-band kits coming out now
Gfunk720 is offline   Reply With Quote
Old 02-18-2009, 05:42 PM   #16
AMS Eric #2
Member#: 85702
2006 Scion xB
What Eric forgot to mention is that tune on top mount was done few months ago when temperature outside were in low single digits and with front mount retune few days ago it was in mid 60's.
AMS Eric #2 is offline   Reply With Quote
Old 02-18-2009, 05:52 PM   #17
Badler
Member#: 133597
You guys just hands down put out some quality stuff. Kudos.
Badler is offline   Reply With Quote
Old 02-18-2009, 06:09 PM   #18
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
agreed. Very impressive from what I've seen so far
Old 02-18-2009, 06:26 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
Eric
boost plots of both tunes?
Old 02-18-2009, 06:53 PM   #20
C J
Member#: 132587
2006 JrTuned STi
[email protected]
ever been to the track?
C J is offline   Reply With Quote
Old 02-18-2009, 06:58 PM   #21
AMS
Member#: 27854
STI, WRX, GTR, EVO,
This was just done about a week ago... so no, no tracks are open out here yet.
Darius
Old 02-18-2009, 07:21 PM   #22
cpturbo
Member#: 49175
2004 STI
AMS, do you care to comment on this post by Phatron? I'd like to know what your thoughts are. What was the real driving affect on throttle response?
cpturbo is offline   Reply With Quote
Old 02-18-2009, 07:26 PM   #23
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Darius
Yeah I figured, really meant to ask what it ran before the power increase?
Old 02-18-2009, 07:45 PM   #24
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
well the reason this specific setup is not making power past 6k is the .63 hotside.
j255c is offline   Reply With Quote
Old 02-18-2009, 09:40 PM   #25
MattPersman
Member#: 139385
isn't topspeed using .63 hotsides and making Timeattack winning power? sure apples to oranges but .63 hotside is not the only reason
MattPersman is offline   Reply With Quote
2008 LGT Spec B -P&L Motorsports V-Band GT30R Kit - 390WHP, 93 oct P&L Motorsports Inc. Proven Power Bragging 60 05-11-2010 02:39 PM
Free Shipping on any AMS V-band turbo kit...gear pack included too! AMS Engine/Power/Exhaust 0 01-27-2010 04:15 PM
AMS V-band GT30R kit on a customer car....with prototype FMIC AMS Mid West Subaru Owners Club Forum -- MWSOC 32 02-27-2009 03:14 AM
Fs:Co: Gt30r kit, sti block, trunk, EcuTek reflashed ecu, fmic. summitwrx Engine/Power/Exhaust 42 01-05-2009 11:44 AM
GT30R kit on 2005 STi - 91 octane STI05 Proven Power Bragging 36 09-27-2005 11:42 PM
