Old 04-08-2002, 04:14 PM   #1
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Default Manual 2002 WRX vs others in traction
In rudimentary understanding of the 5spd 2002 WRX I understand that there is a simple 50/50 power distribution front/rear, with no limited slip diff. Is that correct?
If so, would a 4EAT MY02 WRX or a VW (ugh) w/ 4motion be more stable on snow, wet pavement etc? Anyone know how the Porsche Carerra 4's tranny works?
Does the current european WRX STI have a more advanced tranny? If so, I might wait to see what tranny upgrades they might give us on the US-spec STI
So my question is, is the manual WRX trading some safety in it's simple transmission for "WAHOOO" factor?
Oh and I've been searchin on this stuff and didn't really find anything helpful
aussiebrydon is offline   Reply With Quote
Old 04-08-2002, 04:39 PM   #2
Frederf
Member#: 15622
2002 WRX SW
My little brother knows loads about Porsches. I'll bookmark this post and get his insight later.
Frederf is offline   Reply With Quote
Old 04-08-2002, 04:55 PM   #3
cobra117
Member#: 10325
Default 50/50?
Not as far as I knew.
In my limited understanding of Subarus, the center differential is a viscous type unit that will transfer power from front to rear or vice verca should wheelspin start to occur.
cobra117 is offline   Reply With Quote
Old 04-08-2002, 05:03 PM   #4
hunter001
Member#: 12153
4EAT WRX Wagon Silvr
Acura 3.2TL w/Navigation
Default Re: Manual 2002 WRX vs others in traction
The manual-WRX has a simple 50/50 split but has a limited slip differential.
The viscous-coupling of the manual-WRX by its very nature needs slippage before it can act to correct the slippage by shearing the viscous fluid, thus thickening it and locking the differential.
The 4EAT (of the Auto-WRX, not the Auto-RS) on the other hand, employs a Torque-sensing Planetary Gear Center differential (that the Auto-RS does not have) and a 6-plate Electro-mechanical clutch-pack (Auto-RS has a lighter duty 4-plate clutch pack) to rapidly distribute power front/rear as needed. There is no lag in re-distributing power/torque, like with the manual-WRX.
The Passat 4-motion (same as the A4/non-V8-A6 Quattro) is also very effective, since it too has a Torsen center differential, that acts without any lag in re-distributing power/torque as needed. But the Quattro is much heavier than the Subaru system and is starting to be a little dated.
The STi has a more advanced system (when compared to the manual-WRX AWD), since it has got front and rear Sure-trac mechanical differentials, in addition to the Viscous-coupling in the center.
The Mitsubishi EVO VII has a much more advanced system than the STi, with "Active differentials" similar to the Auto-WRX as the center differential, in addition to having front/rear mechanical differentials.
Later...AH
hunter001 is offline   Reply With Quote
Old 04-08-2002, 06:14 PM   #5
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Default Re: Re: Manual 2002 WRX vs others in traction
Later...AH
wow, a veritable library of information - thanks mate that's exactly what I was looking for
oh I do have a question though, is the EVO VII's tranny setup heavier than theSTI's? (sticks both of them) I know the EVO is faster, but is it because of a LOT more power?
Old 04-08-2002, 10:13 PM   #6
hunter001
Member#: 12153
Default Re: Re: Re: Manual 2002 WRX vs others in traction
The EVO's tranny would definitely be heavier than the STis, but it is a LOT more effective and would ensure much better handling.
The EVO is faster because of the extra power and the way it is delivered. Unlike the STi, which is sluggish below 3000 rpm, the EVO VII has a lot of power/torque down in the lower rpms.
The handling is also much better than the STi, due to the better differentials employed. The STi understeers a lot, unlike the EVO.
But on a day-to-day basis, the STi is a lot more livable, while the EVO is more of a one-track race-car, slightly tamed for the street. The EVO is a lot more expensive too, when compared to the STi.
Later...AH
Old 04-09-2002, 01:30 PM   #7
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
I thought the STi just had a regular diff in the middle, without limited slip to allow for parking brake maneouvers? With the WRX, using the parking brake for turning will eventually damage the limited slip (except maybe in snow), while the STi can use the handbrake when it wants without damage.
Edit: Never mind, I went and checked out the Japan website, the center viscous is there.
SlideWRX is offline   Reply With Quote
Old 04-11-2002, 12:37 AM   #8
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
it just brings a happy tear to my eye seeing so many automotive gearheads coming together and offering advice on my lowly little thread
Old 04-11-2002, 02:40 AM   #9
tifosi77
Guest
Member#: 14110
2002 2002 WRX
Swirly Black
actually the new STi has an electronically controlled center diff, the blank space next to the mirror adjustment thing on the WRX is where a wheel is put in the STi and you adjust the diff but that is all I know.
tifosi77 is offline   Reply With Quote
Old 04-11-2002, 09:31 AM   #10
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
I thought that is only available in 22B not STi. AFAIK, STi has the same center diff as regular WRX.
Foxbat is offline   Reply With Quote
WTB: Glove Box Manual 2002 WRX Chi_San NWIC Private Classifieds 0 08-18-2008 09:09 PM
2002 WRX vs 2002 2.5rs Mr_Snips Newbies & FAQs 18 05-25-2008 04:29 AM
Need a radiator for manual 2002 wrx dojoaxe Private 'Wanted' Classifieds 4 10-17-2005 04:06 PM
WRX vs other cars in performance mods? MikalsWRX Newbies & FAQs 2 09-02-2004 11:43 AM
