Old 02-18-2009, 08:25 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default FMIC and coolant tank ej20g
so......the coolant tank is right where the coolside chargepiping goes....where do i rellocate it so i can mount the FMIC? Also furhter down the coolside, the oil cap and some other things are in the way.
help
JDMFLCL is offline   Reply With Quote
Old 02-23-2009, 08:42 PM   #2
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I have the header tank mounted on the passenger fender well on my STi (Perrin FMIC). To get around the oil filler neck you may have to cut the pipe and have it re-welded so it will fit.
beaviscih is offline   Reply With Quote
Old 02-24-2009, 10:40 AM   #3
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
you need to ditch the stock tank, and come up with an alternative
Perrin has a catch can/coolant overflow that works well
Also, to fit by the filler, you just gotta shove and bend and make it fit
xrocket21 is offline   Reply With Quote
Old 02-24-2009, 10:44 AM   #4
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
You can barely see the top of mine by the hot chargepipe
Old 02-24-2009, 10:53 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
or get a factory in-fender coolant tank
FS: STi Top mount, STi dp, TGVs, and Coolant Tank Silverstg2 Engine/Power/Exhaust 4 11-30-2009 12:15 PM
p/s and coolant tank idea and questions subie12345 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-28-2009 05:01 PM
WTB: EJ20G coolant tank or compatible mpaone Private 'Wanted' Classifieds 4 07-31-2006 08:14 AM
WTB: 96 EJ20G coolant tank suberdave Private 'Wanted' Classifieds 0 05-24-2006 07:38 PM
fmic and coolant hose problems lilrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-16-2003 12:22 PM
