Old 02-18-2009, 10:26 PM   #1
robwrx19720
Scooby Scammer- Do Not Buy From User
Member#: 180582
Default wrx 2.0 block
How much whp can a stock 2.0 wrx motor hold
robwrx19720 is offline   Reply With Quote
Old 02-19-2009, 01:33 AM   #2
03BugEyeRex1121
Member#: 160763
2003 JDM FAIL WRX
Molested By Drunkmann
I'm pretty sure, it's somewhere around 330-350ish (at the wheel)
03BugEyeRex1121 is offline   Reply With Quote
Old 02-19-2009, 01:38 AM   #3
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
even when your 330-350ish your pushing the motor pretty hard.
ownnij is offline   Reply With Quote
Old 02-19-2009, 01:21 PM   #4
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
WRX blocks are semi-closed so if you want really power you should find a full closed block like 2.2 blocks or the STI blocks-- I am not sure but the WRX tranny probably won't be able to handle the torque though you probably have to go with a STI 6spd or an RA or PPG gear set
bugeye-brawler is offline   Reply With Quote
Old 02-19-2009, 01:54 PM   #5
JMack
Member#: 183773
1997 Legacy GT Wagon
Red
WRX and STi blocks are both semi-closed decks, whether it be a EJ205, EJ207, EJ255, or EJ257. The EJ205/7 share the same block, just the internals are different (ie pistons, conn rods, crank) as with the EJ255/7.
To add onto that as well, the RA will not reliably hold 330-350 whp. It's the same material as the stock gears, just different ratios. A 6 speed, PPG set, and MFactory will all hold that. Albeit, the PPG and 6 speed will hold much better than the MFactory, however, it has and is possible to do.
GL though. You have to keep in mind that from the inception of the STi thru 2005 (IIRC, maybe 2007) they used the JDM EJ207 and got the same hp as the USDM EJ257.
JMack is offline   Reply With Quote
wrx 2.0 block build questions unforgiven2144 Built Motor Discussion 3 06-30-2009 11:08 PM
FS: 04 WRX 2.0 block Subiecalifragilistic NWIC Private Classifieds 0 01-06-2009 02:36 AM
FS:CT WRX 2.0 Block/Heads misc. SicWRX37 NESIC Private Classifieds 7 02-07-2008 12:06 PM
Wrx 2.0 Block For Sale jav3323 Private 'For Sale' Classifieds 14 09-05-2006 11:57 PM
WRX 2.0 block 4 sale with other take offs... serious Private 'For Sale' Classifieds 5 10-13-2004 01:03 PM
