Old 02-19-2009, 02:41 PM   #1
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Default Discussion on a CVT
Does anyone produce yet a CVT (constantly varying transmission) for a supercharger yet?
I could see that easily out classing a turbo if they could make something reliable. Can you imagine the supercharger spinning at its perfect speed all the way through the rpm range?
Has anyone seen one produced for a supercharger yet?
Mr_Snips is offline   Reply With Quote
Old 02-19-2009, 03:45 PM   #2
Skidd
Member#: 1853
GC6 Supercharged
STM
This really would only be of benefit to a Centrifugal SC since it needs higher RPMs to make boost.
The roots blower is already great at low RPMs, but struggles as RPM and pressure ratios rise too high.
But... the TwinScrew enjoys the best of both worlds. It can make great boost at lower RPMs, yet still make plenty of boost at higher RPMs too. And unlike the roots, it won't generate gobs of heat as the pressure ratio rises past 2:1.
Skidd is offline   Reply With Quote
Old 02-19-2009, 06:56 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Edit: apparently that is not a transmission
IllNastyImpreza is offline   Reply With Quote
Old 02-19-2009, 07:47 PM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
^ Dude.. you had better re-read the OP.
Old 02-19-2009, 10:51 PM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
hey... he said transmission
Old 02-19-2009, 11:42 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Technically.. yeah.. I know.. your right.. CVT.
But.. ah.. you get the point.
Old 02-20-2009, 07:27 AM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
transmission is used loosley. you could cal in a variable pulley, i dont care. it was to get the point across if that you could spin the SC at ideal speed no matter where you were in the revrange.
Old 02-23-2009, 06:49 PM   #8
jdchmiel
Member#: 926
there are some dual speed SC units, but not CVT.
jdchmiel is offline   Reply With Quote
Old 02-24-2009, 12:18 PM   #9
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i have seen a fair amount of variable pulleys. They are all quite large and heavy so it would take a lot of R&D to make it into a workable size.
also the drag a SC would put on an engine if it was spinning at it's target rpm while the car was at idle would probably cause bogging and other unwanted characteristics.
Zefy is online now   Reply With Quote
Old 02-24-2009, 12:43 PM   #10
2milehi
Member#: 81633
'98 RS-T
Paxton superchargers from the '50s had variable pulley ratios.
Read on - http://images.google.com/imgres?imgu...%3Den%26sa%3DN
2milehi is offline   Reply With Quote
Discussions on LSD Surb00 Transmission (AT/MT) & Driveline 31 12-07-2007 12:34 PM
More discussion on WRX EJ20 heads on EJ18 block required... Kostamojen Subaru Conversions 18 11-23-2003 04:03 AM
Street Racing Spectator Crackdown discussion on NPR touch New England Impreza Club Forum -- NESIC 6 11-27-2002 12:03 PM
Further discussion on HID (purple) - my problem bb Interior & Exterior Modification 6 10-19-2001 07:18 PM
Funny discussion on bimmer.org AudiGuy General Forum Archive 4 08-18-2000 12:25 AM
