Old 04-08-2002, 06:21 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Have a Nice Day? Note to the class: When changing air filters, make sure the box is tight
Mutant Wagon goes in to the dealer's with a lumpy, hesitant idle. It idles fine, then stumbles, then surges, then returns to normal. They hook it up to the diagnostic, call out the local Subaru tech rep (nice guy...loves the P1 wheels and Prodrive exhaust), and they go a pokin'.
Finally, the one tech moves the airbox, and I can see the light bulb come on. Sure enough, he re-fastens it, shoves everything into place, and voila! No more stumble. He cleared the computer of bad learned behavior (it was trying to compensate, and I was running a tad lean), and Mutant Wagon is back, pulling like a locomotive.
The techs there say it's the fastest stock WRX they've ever driven. I'm at a loss, except that I got a good one. I also babied it for the first 1,200 miles or so, adhering to the manual's directives as if they were etched in stone.
So the moral of this story is, if you open that airbox, even if you know about the bottom tab setup (I did) sometimes, you can still hose it off.
Kevin
gtguy is offline   Reply With Quote
how often to change air filter? dodiox General Community 28 06-08-2012 04:03 PM
Changed Air Filter to K&N Big_Mike Factory 2.5L Turbo Powertrain 3 01-21-2009 12:05 AM
Just want to make sure this setup is good before I pull the trigger. cireturbo Factory 2.5L Turbo Powertrain 12 10-25-2007 04:03 PM
Wiring Diagram for MY00-01 ECU need to make sure my FCD is hooked up jdmimpreza Normally Aspirated with bolt-on Forced Induction Powertrain 7 03-15-2006 09:15 PM
Message Board Statistics All times are GMT -4. The time now is 10:30 PM.
