Old 02-19-2009, 05:35 PM   #1
opio
Member#: 184087
2004 2004 wrx
rally blue
Lightbulb Squeaking problem gone!
So guys i have been having this stupid squeaking problem in my car for the longest time. memebers on nasioc were telling me that i can be my endlinks from my sway bars.
So my frist test i went ahead retorque the bolts/nuts --fail still squeaks
2nd someone recommended me that my front endlinks were not the bushing type so its a metal on metal rub, so i decided to buy the bushing type the results -- fail! squeaks like a B still
3rd i removed the endlinks and the car still squeaks without them! i pretty much wasted 100 bucks at this point.
now i know its the coilover so we removed the coilovers and checked it out..we found out what was squeaking and making a creek noise when im turning the wheel the top of the coilover was rubbing on my top hat due to the fact the coilover was not pushed all the way down when screwing the strut bolt on....so it was moving up and down when i would go over bumps..on top of that it freakin grinded my strut stud! luckly the part it was grinding on we didnt need to screw it down that deep =). So we properly installed the coilovers no more squeaks clunking. hope this helps you guys out there =)..if you hear clunking, squeaking, and creeking noises from your car check your coilovers ASAP before it does any more damage! ill post pics of it later btw i did not do the intial install damn shop screwed it up *shakes fist*
opio is offline   Reply With Quote
Swaybar Squeaking Problems Always Return -- How can I stop them for good? Messier77 Brakes, Steering & Suspension 3 04-16-2009 03:17 PM
squeaking problem sonicyellowbugeye Service & Maintenance 3 04-13-2008 11:05 PM
squeaking problem, sudden jolts Mr.Sprinkles Service & Maintenance 4 07-19-2007 04:40 AM
squeaking problem, sudden jolts Mr.Sprinkles Built Motor Discussion 1 07-05-2007 05:18 PM
2005 STi Brake Squeaking Problem Castor Troy Brakes, Steering & Suspension 4 12-07-2004 04:45 AM
Message Board Statistics All times are GMT -4. The time now is 08:57 AM.
