Old 02-20-2009, 01:39 AM   #1
Ruthless671
Member#: 150300
Chapter/Region: HIIC
2006 STi
Default Rubber silicone removal on paint
Well, i just bought a bugeye sedan from this guy. He has some kind of top rear diffuser that he attached with double sided tape and some solf silicone stuff. I pulled the diffuser off and was able to take the double sided adhesive off, but the silicone just won't come off! I tried with a heat gun, hair dryer,WD 40, Wax, Alcohol, WTF!! Can someone help me out! Thanks in advance.
Ruthless671 is offline   Reply With Quote
Old 02-20-2009, 11:56 AM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....a thought came to mind.... You may have heard how some use fishing line to remove badges/emblems. How about running a line through the silicone in a slow sawing motion? ....as close to the paint as possible. If you can remove the majority of it and are left with a thin coat, it may be easier to deal with. Personally, I would probably just hit it with my buffer at that point (with a moderate polish) which would likely cut right through the remaining layer. ....vs. expirementing with different solvents.
Kean is offline   Reply With Quote
Old 02-20-2009, 12:49 PM   #3
Ruthless671
Member#: 150300
2006 STi
good idea. i will try that, instead of using different kinds of solvents. thanks.
Old 02-27-2009, 09:11 PM   #4
tinkz
Member#: 135776
2005 WRX WRP10
Use wax and grease remover with a clean rag and rub to remove silicone. I used this to remove silkaflex glue
tinkz is offline   Reply With Quote
Need some advice on silicone removal from paint. Nivekk Interior & Exterior Modification 0 07-29-2007 05:14 PM
Painting WRX skirts, but now what to do with the rubber gasket thing on the top?? itachi1314 Vancouver Impreza Club Forum -- VIC 8 02-15-2007 11:27 PM
Removing dry paint on carpet SupraScooby Interior & Exterior Modification 3 03-12-2005 07:17 AM
How to safely remove the paint dot on the tire? armand1 Tire & Wheel 11 05-24-2004 06:31 PM
How to remove stain on paint? pntballfreak Interior & Exterior Modification 9 05-27-2003 11:29 AM
