Old 02-20-2009, 11:22 AM   #1
325abn
Member#: 203535
Default AWD Not working
Hello All
I have a 96 Legacy LS 2.2 Autotranny with 177K on the clock. The AWD is not working with no power to the rear wheels. There are no lights on the dash that stay on, the FWD fuse slot is empty.
So I am assuming that duty solenoid "C" is gone or the clutch pack is gone. Is there a way for me to test the solinoid?
I just got this car the other week dumped a bunch of money into it for state inspection, then it snowed this AM and it became very clear the AWD was not working.
If I install a fues into the FWD fuse slot the FWD loght on the dash does come on.
So if I choose not to fix this issue how long could I expect the tranny to work?
If I choose not to fix it would it be better to install the FWD fuse and/or remove the rear drive shaft?
Thanks in advance for any input!!
325abn is offline   Reply With Quote
Old 02-20-2009, 02:41 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
try asking in the transmission forums.
Old 02-20-2009, 04:41 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I concur you'll probably have more luck asking here.
Sounds to me like installing the FWD fuse is a somewhat moot point, as the center diff has already been disabled via some sort of fault. But I'm definitely no 4EAT expert, so I could be wrong.
AWD not working Jutboy Normally Aspirated Powertrain 6 12-24-2008 10:37 PM
Help: AWD not working BakedPotato Legacy Forum 17 09-25-2007 08:42 PM
97 OB Auto...AWD not working! bbren Outback Forum 9 04-15-2006 01:55 AM
AWD not working! Help! MekoNY Legacy Forum 14 12-13-2005 01:07 PM
91 Legacy AWD not working - help kooskia Legacy Forum 10 12-08-2005 02:12 AM
