Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 02-20-2009, 06:16 PM   #1
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Default SCCA Solo class?
I am having trouble figuring out if I will qualify for STU, Street Prepared, or Street modified. I will be driving my daily drivin 2007 Subaru STi.
Performance Modifications:
-Turbo back exhaust with high flow cat
-Ported and Polished exh manifold
-Cold air intake
-aftermarket boost control solenoid
-larger top mount intercooler
-larger fuel injectors and higher capacity fuel pump
-obviously tuned
Suspension Modifications:
-Right now just stiffer aftermarket springs
-Hopefully swaybars before the season starts
-Larger wheels
-tires to be determined depending on what class I qualify for (either 245 or 255 width)
-DBA 4000 slotted rotors with hawk hps pads
rxer311 is offline   Reply With Quote
Old 02-20-2009, 09:03 PM   #2
Boxologist
Member#: 21118
STu is a 235 width tyre iirc. i think teh PnP is SM, but someone else will give more definitive answer.
Boxologist is online now   Reply With Quote
Old 02-20-2009, 09:15 PM   #3
Chiketkd
Member#: 71634
In hibernation...
Max tire size is 245 in STU for awd cars (note: tires must have a treadwear of 140 or higher).
Looking at these mods, you're in BSP (B Street Prepared). You can remove the cat and go catless and still be legal for the class if you wanted.
Have fun!
Chiketkd is offline   Reply With Quote
Old 02-20-2009, 09:40 PM   #4
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I second BSP do to these mods.
You are also alloed unlimited boost in BSP.
Patrick L is offline   Reply With Quote
Old 02-20-2009, 10:19 PM   #5
68Cadillac
Member#: 95901
Anyone of those modifications disqualify you for a Street Touring classification (i.e. STX, STU)
68Cadillac is offline   Reply With Quote
Old 02-20-2009, 11:10 PM   #6
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Street Mod or BSP due to the tune if you are running higher than stock boost.
speedyHAM is offline   Reply With Quote
Old 02-21-2009, 09:10 AM   #7
Aaron B
Member#: 67924
2003 #25/125 STX WRX
I believe boost changes in SP can only be handled at the ECU level, so the boost controller would knock you into SM
Aaron B is offline   Reply With Quote
Old 02-21-2009, 10:21 AM   #8
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Thank you for the responses guys. So far it looks like the consensus is Street preparted or Street modified. Hopefully somebody will have a definitive answer.
Even though I have a boost control solenoid by boost is still handled by my ECU. It is not a Boost controller, it is actually just an upgraded solenoid that makes the car easier to tune.
Old 02-21-2009, 11:05 AM   #9
elirentz
Member#: 70082
2016 SS, 02 s2k
06 Cayman S, 80cc shifter
This is from the 09 scca rulebook regarding your boost control solenoid in BSP:
f) Boost regulation systems, either electronic or mechanical,
and electronic fuel cuts referencing boost pressure may be
altered or modified except as prohibited herein. Boost
pressure changes resulting from authorized changes are
permitted.
this is from ~pg. 93 in the rule book if you want to read further.
elirentz is online now   Reply With Quote
Old 02-21-2009, 09:16 PM   #10
Chiketkd
Member#: 71634
In hibernation...
As elirentz pointed out above, mechanical boost changes are allowed in SP. To the OP, you're definitely legal for BSP. Have fun autocrossing!
Old 02-21-2009, 09:23 PM   #11
digitalseance
Member#: 104400
169k mile race car
All you need now is some hoosier crack.
digitalseance is offline   Reply With Quote
Old 02-22-2009, 09:39 AM   #12
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Thank you guys. My challenge now is going to be how to find a Cheap tire that is going to perform well (budget is streched to the limit as it is).
SCCA Solo classing question Splinter Motorsports 16 02-04-2009 10:27 AM
In which SCCA solo class do I belong? Thony Motorsports 36 02-04-2008 09:25 AM
SCCA Solo Classing Question - Baja Turbo KC Motorsports 8 08-13-2005 12:45 AM
SCCA Solo Class? (new STi) a2cpc Motorsports 27 01-09-2003 07:30 PM
Question about Vehicle class in SCCA Solo II Vestas Tri-State Area Forum 2 06-04-2001 05:49 AM
