#1 |
Member#: 175238
South East
Vehicle:2004 WRX black. |
As the title states, I swapped in a full STi engine/tranny/wiring into my 04 WRX. I did not swap the gas tanks and I already had a whalbro installed from my WRX mods. Now I am getting a P0230. What do I need to get off of the STi to keep this from happening again? I still have the STi gas tank and fuel sender, but I need the whalbro because of my EVo3 and supporting mods.
#2 |
Member#: 147056
Vehicle:7 sti |
#3 |
Member#: 104686
Vehicle:2005 WRX www.Spun-Autosports.com |
Use your 04 wiring harness in the rear. This is the harness that connects under the rear seat. Splice the 07 STI harness that you used for everything else into that harness. I did the same swap and did not want to swap the tank. This is what I did and the code went away. Im pretty sure all the wires are the same color as well. Its been a while since I did it.
#4 |
Member#: 175238
South East
I really don't want to swap harnesses again. And I'm getting conflicting diagnosis here. One thing I did not swap was th efuel sending unit. I had already installed the whalbro and thought I would not need to swap the unit out. I swapped the sensor that is in the RR above the IC tank, that is STi along with th ewhole harness from headlight to tail light. Does onyone know if I need to swap the sending unit oout of the gas tank? Will the STi fuel pump push enough fuel for the 750 cc injectors and IWG EVO3 that I have? Based on what others have done, did you get this CEL and if so exactly how did you fix it?
#5 | |
Member#: 98961
Vehicle:2003 WRX Black |
I'm pulling the tank today. It looks to me like the pinout of the white connector under the rear seat is different between the 05 STI Doner harness and my 03 WRX Harness.
You can install the walbro into the STI fuel pump assembly. I'd verify that the pinout on the white under-seat connector is the same between the doner and this harness. |
#6 |
Member#: 175238
South East
I guess I may have figured it out. The bolts holding the controller to the chassis were loose. I tightened them and cleared the light, it hasn't come back yet. I'll just wait and see. I can replace the sending unit with the sti if I have to.
#7 |
Member#: 98961
I liked the STI unit because it moved the fuel filter into the tank and cleaned up the engine compartment.
#8 |
Member#: 175238
South East
The code came back........
Now I know the car that the controller came out of did not have this problem. I do not have the time to pull the tank again, and the only thing differant between my setup and the STi donar is I kept my gas tank and fuel pump. Is there any way possible that the code could be because of the lack of the STi internals in the fuel tank? all of the sensors were the same on the tank except the WRX has one extra evap solonoid, which I removed and blocked off the hose going to it. |
#9 |
Member#: 98961
I'd follow the trouble-shooting procedure in the manual. It shows you how to diagnose this.
| Thread Tools | |
| Display Modes | |
| 05-07 rear aprons on my 04 wrx? | lowrider89 | Interior & Exterior Modification | 3 | 12-21-2009 11:17 PM |
| 07 OEM Sti Turboback to my 04 wrx | macdarwin | Factory 2.0L Turbo Powertrain | 1 | 08-08-2008 06:36 AM |
| My Dodge Neon BUG EYE STI vs. My 04 WRX (Thought this was funny) | Econoboost | General Community | 15 | 07-29-2008 05:26 PM |
| Tribute video to my 04 WRX.. RIP Scooby | RC0310 | Off-Topic | 11 | 01-03-2007 09:23 PM |
| Can I swap an STii steering wheel badge into my 04 WRX? | EntrustXXXX | Interior & Exterior Modification | 13 | 03-05-2006 12:12 AM |
