Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 02-21-2009, 12:44 AM   #1
Speeding101
Member#: 160955
work working on it
working on it
Default motor swap from 02-03 to 06-07
is it possible?
i have heard of an ej25 going into a body designed for an ej20 but can an ej 20 go into a body made for an ej25?
Speeding101 is offline   Reply With Quote
Old 02-21-2009, 01:21 AM   #2
Speeding101
Member#: 160955
work working on it
working on it
need help bad!!!
Old 02-21-2009, 02:00 AM   #3
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
It can be done, but you also need to swap the wiring harness.
Why would you want to do this in the first place?
rexworx is offline   Reply With Quote
Old 02-21-2009, 01:51 PM   #4
Speeding101
Member#: 160955
work working on it
working on it
thank you... i have the wiring harness... but would i only need to redo from ecu to enginge bay. or should i rewire the entire car?
Old 02-22-2009, 01:58 AM   #5
EsubaruJ
Member#: 200008
85 AE86
01XJcrawler02WRXsold
I would assume it would just need to swap the bulkhead, you would just have to splice into the factory harness. But I am curious as to why you want to swap to an ej20..
EsubaruJ is offline   Reply With Quote
Old 02-22-2009, 02:00 AM   #6
Speeding101
Member#: 160955
work working on it
working on it
well i wrecked my 03 beyond repair and i have an 06 body... so...
well you get the picture!!!
Old 02-22-2009, 02:02 AM   #7
EsubaruJ
Member#: 200008
85 AE86
Oh i see lol. Yeah all you will need is the bulkhead from the bugeye and you will just splice it into the rest of the factory harness of the hawkeye. Pull the motor before the harness lol.
Old 02-22-2009, 02:17 AM   #8
Speeding101
Member#: 160955
work working on it
working on it
well im going to pull the motor out of my bugeye... then i am going to pull the harness and ecu out... place ecu and harness into the hawkeye...
does that sound right?
Old 02-22-2009, 02:31 AM   #9
EsubaruJ
Member#: 200008
85 AE86
Is there an existing harness in the hawkeye?
Old 02-22-2009, 02:32 AM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
this is a bad idea....there are MANY issues other than the cable throttle/dbw throttle
the 06 has avcs and the earlier has not
just a bad idea
Old 02-22-2009, 02:37 AM   #11
Speeding101
Member#: 160955
work working on it
working on it
yes there is an existing harnes in the hawkeye...
just a bad idea
ok? but if i strip the body straight down to bare metal and nothing else will that matter?
im going straight from one to the other...
Old 02-22-2009, 02:42 AM   #12
1sicWRX
Member#: 104631
99 911 Carrera
03 Land Rover Disco SE7
just a bad idea
I don't see how it's a bad idea if he swapping in engine, wiring harness and ecu out of his bugeye into a shell of an 06. It's basically the same car. AVCS would not apply nor would drive by wire if he plans on ripping out all the existing leftovers of the 06...
1sicWRX is offline   Reply With Quote
Old 02-22-2009, 12:14 PM   #13
Speeding101
Member#: 160955
work working on it
working on it
ya... well im not even sure what this AVCS is...
bu7t if it has something to do with drivetrain then that is going too!!!
Old 02-22-2009, 01:28 PM   #14
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
god...where DO these people come from ?????
putting a USDM ej205 2.0 into an 06 is like putting a v6 in z28 camaro
waste of time
plain
pure
and
simple
this is one of those 'watch this' ones on youtube that everybody laughs at because it is so stupid
Old 02-22-2009, 01:32 PM   #15
autvincereautmori
Member#: 137832
02 02 PSM WRX
05 OBP STI
waste of time
plain
pure
and
simple
so do you think that everyone who does a front end conversion is wasting their time i think it would be a great idea.. the hawkeye has better brakes and looks better imo.. plus he has the shell and his 03 is wrecked to hell so why not? i love the 2.0 that i have for the high revs..
autvincereautmori is offline   Reply With Quote
Old 02-22-2009, 03:11 PM   #16
MUGWUMP
Member#: 13170
2012 New Hotness
Part out bugeye for $$ for 06+ drivetrain?
MUGWUMP is offline   Reply With Quote
Old 02-22-2009, 03:18 PM   #17
1sicWRX
Member#: 104631
99 911 Carrera
waste of time
plain
pure
and
simple
Where do people like you come from?? Your snobbery is sickening. I'll be the first to admit that you give great advice all the time but just because you give it, doesn't make it correct because "Uncle Scotty" said it. He has an 06 lying around with no motor in it and an 03 that is now damaged beyond repair, and instead of buying a new car he can easily swap the powertrain out of his existing one. IT'S MORE OF A FINANCIAL DECISION THAN ANYTHING. I don't see what's so stupid about it. If he had an 06 with a working 2.5 and swapped a 2.0, yeah, it would be retarded but that is not the case here. It's the same ****ing car without a motor in it. It's nowhere near your comparison of a v6 going into a Z28 either. The s EJ205 makes identical hp numbers to the 2.5. Not all of us here can afford to buy a new car nor $1800 to buy a new shortblock, especially if he practically has an extra WRX just sitting around with a capable WRX motor to put in it.
Old 02-22-2009, 11:09 PM   #18
03silverblt
Member#: 163367
03 wrx stg1
/\/\/\ LOL, I also agree with the above comment, if you have 2 spairs make 1 out of it and a 2.0 is nothing like compairing and putting in a v6 into a z28. haha
I think you should call TRAN and get an SR420DET in there. Heck call Bryan Spilner and order 3 straight from Japan. j/khaha
03silverblt is offline   Reply With Quote
Old 02-23-2009, 04:00 AM   #19
Speeding101
Member#: 160955
work working on it
working on it
thank you... ill keep all informed and updated on the progress
Old 02-23-2009, 12:12 PM   #20
1sicWRX
Member#: 104631
99 911 Carrera
For sure man, good luck!
Old 02-23-2009, 12:46 PM   #21
deebee8
Member#: 85437
2002 Wrx
Land of the dead
waste of time
plain
pure
and
simple
im so sick and tired of your useless posts.
this guy made it clear as mud what he has.
HE HAS AN 06 SHELL
HE HAS AN 02 MOTOR, ECU, AND WIRING HARNESS
Straight forward swap.
There is ABSOLUTELY nothing wrong with that.
Both the 06 motor and 02 motor produce the same amount of HP stock.
Why would you even try and question him.
deebee8 is offline   Reply With Quote
Old 02-23-2009, 01:31 PM   #22
Speeding101
Member#: 160955
work working on it
working on it
HE HAS AN 06 SHELL
thank you yet again!!!
02-03 Tails, 06-07 Tails, 02-03 Wheel wAB, ORLANDO!!! HighwayStarPP South East Region Private Classifieds 2 04-25-2010 03:46 PM
possible front end swap WTT from 02/03 to 04/05 PSM WORunner Private 'Wanted' Classifieds 2 02-28-2009 03:20 AM
motor swap from 02-03 to 06-07 Speeding101 Factory 2.5L Turbo Powertrain 6 02-21-2009 01:48 PM
Moving parts from 02 wagon to 06/07 wagon sborderz Factory 2.5L Turbo Powertrain 1 04-24-2007 03:00 PM
Message Board Statistics All times are GMT -4. The time now is 10:57 PM.
