Old 02-27-2013, 11:40 AM   #1
Motion Lab Tuning
Member#: 228856
Default Motion Lab Tuned 2009WRX 320whp/379wtq Stock turbo delivers some surprising results!
Shop: Motion Lab Tuning
Dyno Type: DynoCom FX5000-AWD
Temp: 43F
Boost: 21psi
Fuel: 93OCT unleaded
Target AFR: 11.5:1
SAE Corrections: Default Corrections
Peak HP at RPM: 320whp @ 4800 RPMs
Peak Torque at RPM: 379wtq @ 4350 RPMs
Transmission: WRX 5speed
Gear: 3rd
Engine Management: Opensource
Engine/Power Modifications:
  • Perrin Performance Aluminum TMIC
  • Invidia Catted downpipe w/ Grimmspeed adapter
  • SPT Tuning Catback exhaust
  • Motion Lab Tuning 3-port EBCS
This is 2009 WRX we finished up several weeks ago. Car had the OEM VF52 and a pretty fresh motor. He had an unfortunate failure very early in the ownership at the car so it had a new motor installed at 18,000mi. The weather was pretty cool out and kept the TMIC nice a chilled in-between pulls. The car was totally stock and he contacted us for a solid "stage2" set-up. He liked how quiet the SPT exhaust was so we kept that in place and added a Invidia catted downpipe to the mix. Because we didnt want to limit the results of the dyno tuning I recommended the addition of the TMIC versus adding an intake or up-pipe into the mix. Its a bit more expensive but the results speak for themselves when we can push 21psi versus 17psi on the OEM TMIC. It gets you a huge bump in torque in the mid range. He is happy with the power for now, only expected additions in the near future are the nice RCE Black springs and a Kartboy shortshifter and shifter bushings.
Final HP/TQ Graph:
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
[email protected]
MotionLabTuning.com - Engineering Performance
Motion Lab Tuning is offline   Reply With Quote
Old 02-27-2013, 03:57 PM   #2
KingPest
Member#: 194894
2013 BRZ
2005 STi
That's a pretty generous dyno if it is saying that a stock car is putting down 310 wheeltorque.
KingPest is offline   Reply With Quote
Old 02-27-2013, 04:26 PM   #3
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
will the injectors be over 100 at WOT?
BroBroBroBroBro is offline   Reply With Quote
Old 02-27-2013, 04:44 PM   #4
Motion Lab Tuning
Member#: 228856
Sorry I should have clarified. The black line was our baseline map that Todd made at his desk as a starting point. Once we added boost and ignition timing into the base map, the final results are the pink lines.
We have quite a few graphs posted up over the past few weeks so you can just poke around for a reference on how our dyno reads. We have found it to be fairly close to the Mustang MD-150 we used to rent.
No these injectors saw a peak IDC of ~%95 which is about as far as we like to push the OEM Denso top feeds.
Thanks,
Alex Goodwin
[email protected]
