Old 02-21-2009, 07:51 PM   #1
trancet
Member#: 155971
1999 Impreza Coupe
EJ205 Inside
Default ITB Idea that i saw, opinions?
Was at Motorama today and saw this
Dont know a thing about it other then its on a JDM 2.0, coil on plug, in a 4door 98 RS
What do you think of it? a waste? worthwhile ?
trancet is offline   Reply With Quote
Old 02-21-2009, 08:06 PM   #2
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
Check this thread out, The guy has since scrapped his Idea and Is selling what he has left but he had It running and said It was awesome.
Read through the thread Its got alot of good Info.
Edit:
It helps If I post the link lol
http://forums.nasioc.com/forums/show....php?t=1175829
07wrx4life is offline   Reply With Quote
Old 02-22-2009, 12:50 AM   #3
trancet
Member#: 155971
1999 Impreza Coupe
EJ205 Inside
^ Very nice, just wondering if this is a less expensive alternative, but does it add enough of a benefit at all due to the location of the ITBs ?
Old 02-22-2009, 11:13 AM   #4
mt72
Member#: 199195
2007 Sierra 1500
white
I have run ITB's on my previous RSX and in order to have nice benefit you need to build a complet block ... it's not less expensive belive me
i just dream of the day turbo ITB's application
mt72 is offline   Reply With Quote
Old 02-22-2009, 11:59 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
... this is a less expensive alternative, but does it add enough of a benefit at all due to the location of the ITBs ?
I'm certainly no ITB expert, but my thinking is NO, it doesn't add much benefit. I guess the fact that the throttle plates are downstream of the plenum would help throttle response, but you've still go the whole runner to fill when the throttle cracks open. Seems like you're only getting about 1/2 the benefit.
If the ITB experts come in here and say it does add enough benefit then that might be something I'll look into doing.
Originally Posted by mt72 View Post
I have run ITB's on my previous RSX and in order to have nice benefit you need to build a complet [sic] block
I don't follow your logic here.
Pat Olsen
Old 02-22-2009, 12:19 PM   #6
mt72
Member#: 199195
2007 Sierra 1500
white
Pat Olsen
well on a NA engine if you don't add cam high comp piston your effort to have HP gains useless ....
Old 02-22-2009, 12:52 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
The setup in those pics look interesting, though almost every ITB setup I've looked at has a taper formed into it. Those ITB's would have the taper going the wrong way and hurting more than anything. If they are shaped to flow that direction, it doesn't seem like a terrible idea, though the butterflies should be closer to the valves to reap the most from it.
Jay Storm
Old 02-22-2009, 03:59 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
ITBs are a part of the puzzle, just like every other modification one can make to an engine. One of the primary benefits is not to gain power but to drastically improve throttle response - that benefit would be there regardless of whether one had raised the CR.
Jay Storm
It's hard to tell, but it looks to me like the end pointed towards the heads is smaller than the entry bolted to the intake plenum. With that said, most ITBs are designed to bolt to the cylinder head, in which case flow would be heading the opposite direction. If these are "typical" ITBs mounted backwards then I agree wholeheartedly.
Pat
Old 02-22-2009, 04:28 PM   #9
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
i was just talking to my buddy last night about ITBs and i was looking at the rb26 stock itbs and thinking i could modify them to work on the subaru head but that is one big project to start and dont have the time right now.
wopdeeze is offline   Reply With Quote
Old 02-22-2009, 06:33 PM   #10
trancet
Member#: 155971
1999 Impreza Coupe
EJ205 Inside
from what i remember from looking at it, it does, but not a whole lot.
Old 02-22-2009, 09:00 PM   #11
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Im running ITBs atm and i can tell you the benefit is defiately worth while.
However the pic that the OP posted has the ITBs to high up imo to really be benefical. U need the ITBS to be as close the heads as possible for increased TB response as there is less volume of air to fill...
heres a pic of my setup..
tino is offline   Reply With Quote
Old 02-23-2009, 06:05 AM   #12
Einimas
Member#: 176111
Sick, are those modified tgv's?
Einimas is offline   Reply With Quote
Old 02-24-2009, 07:38 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cool....I had a feeling that butterflies could be fashioned to work inside TGV housings. Any additional clearancing required to allow full range of motion? The walls taper into a different shape (than round) from what I can tell.....
Jay
Old 02-24-2009, 10:01 AM   #14
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Jay
they were no doubt done on a CNC by....crap, I can't remember the aussie company who makes the pretty cnc intake manifolds
Old 02-24-2009, 07:13 PM   #15
sku81
Member#: 143283
2001 bugeye wrx
white
I can tell u right now that they had nothing to do with the TB set up.
Kris
sku81 is offline   Reply With Quote
Good Idea or Dumb Idea? That is the question... Impreza2.5RSTi Off-Topic 31 11-07-2006 04:35 PM
what do you think of my idea to promote fitness? *opinions needed* skimmilk68 Off-Topic 5 11-10-2005 03:37 PM
Who was that that I saw in my town??? (harbor springs, white WRX) tooocool49723 Mid West Subaru Owners Club Forum -- MWSOC 3 12-28-2004 02:22 AM
Paulrex! Was that u that i saw? MACHWRX Tri-State Area Forum 8 10-16-2003 09:37 PM
since there are a couple of ppl that have had opinions that the t shirt are "tacky" [27] Texas Impreza Club Forum -- TXIC 26 10-08-2003 03:39 PM
