Old 04-09-2002, 12:07 AM   #1
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Default Burning oil smell?
I've got a burning oil smell emanating from somewhere around the headers or cat. When I turn off the car it even smokes a bit down there. I did not spill any oil during my last oil change. It only started smoking a few hundred miles after my last oil change.
Anyone have any ideas as to what could be causing this?
Arnie is offline   Reply With Quote
Old 04-09-2002, 02:43 AM   #2
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
this happened to me right after i installed my engine/tranny mounts. It smoked like mad for like the first 10min, then went away, i had no idea what was going on.
FatCatTurbo is offline   Reply With Quote
Old 04-09-2002, 08:26 AM   #3
99OBSter
Member#: 14324
1999 OBS 4eat
I would check your seals. See if your crank seal is leaking. Do you notice any oil on the ground?
99OBSter is offline   Reply With Quote
Old 04-09-2002, 01:08 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I can't say I've noticed any oil on the ground but I'll have to check next time. One factor is I think I may have had about 1/2 to 1 quart too much oil in the car. I changed oil with the front up on ramps and I'm suspecting that not all the oil was drained out because after it started smoking I checked the dipstick (after wiping) and the oil level was over the "F" mark. I have since drained a bit of oil to get it to the proper level.
By the way, what seals should I be checking and where are they located?
Thanks for the tips so far.
Old 04-10-2002, 08:34 AM   #5
99OBSter
Member#: 14324
1999 OBS 4eat
You know, i can't really say I know exactly where the crank seal is... It's somewhere close to the timing belt, but behind it.
burning oil smell after oil change happs subi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-02-2009 12:37 PM
Burning Oil Smell Scooby2 Newbies & FAQs 9 03-22-2007 02:53 PM
Slightly Burning Oil Smell? SJwrx Newbies & FAQs 3 12-05-2002 09:08 PM
burning oil smell after oil change? wrxinfx Service & Maintenance 4 12-12-2001 09:13 AM
