Old 02-21-2009, 11:17 PM   #1
94legacy2.2
Member#: 203177
Default switching from side feeds to top feeds
Just wondering if anyone has done it and if they had to have spacers/plugs made for the hole on the side feed manifold.
If you have it done or know where to get more info please let me know. I searched to about page 15 and no luck
Thanks
Tyson
94legacy2.2 is offline   Reply With Quote
Old 02-22-2009, 04:33 AM   #2
col5555
Member#: 142017
Yes it can and has been done. There is a company in the United Kingdom that make a conversion kit. I cant for the life of me remember who it is at the moment but if you do some googleing I am sure you will find it. If no one else chimes in with the name I will find out. Just remembered Davey Clark or David Clark or close to it.
col5555 is offline   Reply With Quote
Old 02-22-2009, 04:49 AM   #3
col5555
Member#: 142017
Sorry! the name is Carl Davey
Old 02-22-2009, 12:56 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
PM me if you'd be interested in these....
Old 02-22-2009, 01:21 PM   #5
shwoop_soobie
Member#: 102323
99 power poles
beware
ultimate racing makes top feed conversions
pricey to say the least
shwoop_soobie is offline   Reply With Quote
Old 02-22-2009, 08:38 PM   #6
94legacy2.2
Member#: 203177
PM sent to Storm
Old 02-23-2009, 09:36 AM   #7
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Hope it doesn't sound like a dumb question, but what is the benifit to switch from a side feed to top feed? Also is there a benifit to switch the top fuel rail on a top feed set up with larger injectors.
birdman.1 is offline   Reply With Quote
Old 02-23-2009, 09:49 AM   #8
94legacy2.2
Member#: 203177
The main benefit is the market for top feed injectors.
also the side feed rails dont like to flow injectors above 800cc or so.
Im planning on switching to top feeds with my car and with another car. The other car will be running 1000cc top feeds with e85
Old 02-23-2009, 10:00 AM   #9
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Ah excellent. Thank you. I have a 2003 WRX and i guess it comes with factory top feed injectors. Is there also a benifit to change the rails when doing a larger set of injectors? I have seen a few companies that offer fuel rail kits and not sure what that benifit would be,
Old 02-23-2009, 10:02 AM   #10
94legacy2.2
Member#: 203177
na no benifit to it, just looks. Now once you start making 400+ maybe a tad lower then you might out flow your stock rails. But by then you should have a pimp setup and want new rails cause they look purty
Old 02-23-2009, 11:34 AM   #11
birdman.1
Member#: 203611
2003 WRX
World Rally Blue
Ah, I am currently bulding this out for a back up car in time attack. I am aiming at 430-500 whp. I 've got a good project ahead of me and it sounds like im on the right track from my local guy. Thank you for the info.
Old 02-23-2009, 12:03 PM   #12
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Much easier to just buy some top feed TGV's, and use some wrx fuel rails. Then find a wrx harness to steal the injecter plugs from then your set.
Token-Negro is offline   Reply With Quote
Old 02-23-2009, 05:37 PM   #13
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
Will the TGV's work on the older intakes? I highly highly doubt that
turboed22 is offline   Reply With Quote
Old 02-24-2009, 12:18 AM   #14
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Fuel rails are benefitial for a few reasons.. The biggest reason is a more even distribition of fuel to all cylinders.. The stock setup is rather restrictive and tends to starve cylinder # 3. Also increasing the line size will help flow more fuel to each cylinder.. That's never a bad thing.
bigmike25rs is online now   Reply With Quote
Old 02-24-2009, 12:46 AM   #15
MartinSTi05
Member#: 145145
2006 wrx STi
yeah, having the rails in series, the input on one side and the reg on the other is terrible as far as distribution goes.
MartinSTi05 is offline   Reply With Quote
Old 02-24-2009, 12:50 AM   #16
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Why are you going through the hassle unless you need larger than 800cc injectors?
Old 02-24-2009, 07:32 AM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
Set your PM box to accept replies then......
Originally Posted by 94legacy2.2 View Post
PM sent to Storm
Old 02-24-2009, 08:51 AM   #18
94legacy2.2
Member#: 203177
damn inbox.
ill do it now
Old 02-24-2009, 08:53 AM   #19
94legacy2.2
Member#: 203177
Hey storm try that now and see what happens
Old 02-24-2009, 01:50 PM   #20
turboed22
Member#: 93364
'14 BRZ
He was also posting for me. We were both wondering. I want to run 1000-1200 cc eventually. There are also much much cheaper options for large top feeds as opposed to large side feeds.
Old 02-24-2009, 02:20 PM   #21
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
I am almost done building custom brackets for my conversion. Just plan out what you need to make it fit then take everything to a machine shop and tell them exactly what you need. I was able to have a piece of aluminum milled to the thickness I needed for a 6 pack of beer. Drill a couple of holes with a counter sink and your are in business. Kind of a pain in the ass but a cool little project no less. I did all of the fabrication with my friend as the machine shop charges $100/ hr for labor. Now I have to have my aftermarket fuel rails machined to fit the bracket I made. It's amazing how persuasive some ice cold beers can be
I can take pics if you want an idea of what your lookin for.
hustleshark206 is offline   Reply With Quote
Old 02-24-2009, 06:39 PM   #22
94legacy2.2
Member#: 203177
pictures are always good. Please share
Old 02-24-2009, 07:13 PM   #23
hustleshark206
Member#: 182227
2000 MPS Built RS
Ok, no problem. I will try to get some pics up for you tonight
Old 02-24-2009, 10:01 PM   #24
hp1050
Member#: 89472
Google "Carl Davey" he does a sidefeed to topfeed conversion kit with brackets.
hp1050 is offline   Reply With Quote
Old 02-24-2009, 11:51 PM   #25
turboed22
Member#: 93364
'14 BRZ
read a few posts up. Someone already mentioned him
FEELER (MIAMI)parts to swap from side feed to top feed davidsti1 Private 'Wanted' Classifieds 3 10-19-2009 09:31 AM
Side feed to top feed fuel rail conversion project_skyline Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-21-2008 04:09 AM
side feed to top feed??? legacydreamz Legacy Forum 0 04-20-2006 10:00 PM
STI WRX ultimate racing side feed to top feed fuel injectors & rails kit 785cc Ricowrx Private 'For Sale' Classifieds 8 11-28-2004 05:52 PM
Side feed to top feed injector question ttimpreza Subaru Conversions 1 04-12-2004 05:56 PM
