#1 |
Member#: 184958
I own a 2002 WRX hybrid
Brand new STI short block Wiesco Drop in's Walb. 255 DW 850 cc STI cams TGV deletes 08 STI oil pump 08 STI water pump New 5spd with about 7k Deadbolt 20g Invida Divorced DP catted CSS top mount (dont purchase anything from them) Exedy stage 1 clutch brand new oem flywheel stage 1 clutch brand new oem fly Open source tune target 18psi MAF maxed out How would my car do against a stage 2 sti? not from a launch because i know somone is going to post something along the lines of " it depends on the driver" i just really want an idea, there are really not to many subaru's in the area...
#2 |
Member#: 203275
Vehicle:2006 WRX SBR 20G More boost to come! |
Maybe this should be in the newbie or general forum... |
#3 |
Member#: 184958
and maybe it shouldn't?
#4 |
Member#: 162942
Vehicle:2006 STi Black&Gold Stage 2 |
lol, a 20G WRX would rape a stage 2 sti.
#5 |
Member#: 147628
South East
Vehicle:2011 MAN-WAGON Silver |
If it's tuned right, it should pull away pretty handily. Especially once you start winding it out all the way.
CSS, snicker! (I was in on the 1st group buy.) |
#6 |
Member#: 176670
SWIC
Vehicle:2006 30r STi on E85 WRB |
That would destroy at Stage 2.
#7 |
Member#: 59238
SWIC
you will eat his A@@. from a light, a dig, you will pull mad
#8 |
Member#: 102808
Vehicle:2002 v8 EJ207 v7 6spd FP Green |
you gonna lose. ib4tl
#9 |
Member#: 107323
Vehicle:2005 Impreza WRX 16g Crystal Gray Metallic |
He will have you intitally but when you 20 spools up you will be out like a boner in sweatpants.
#10 |
Member#: 115149
Vehicle:07 STI Murdered & Loud |
not that it matters greatly, but is it a 8cm or 7cm and a TD06...
it will definetly pull on a stage 2 sti |
#11 |
Member#: 50221
Vehicle:I'm on internets Racin on ur bandwidth! |
If you're on a wrx 5-speed you will eat a stage 2 STi for lunch.
From a dig, from a roll.. everything but a road course. |
#12 |
Member#: 104876
NESIC
Vehicle:2003 WRX, HEMI Jeep, DD Honda Accord |
#13 |
Member#: 114631
Vehicle:2007 11.5 @ 118 Stock Turbo Record Holder |
#14 |
Member#: 129231
Vehicle:2005 wrx cgm |
remember that a hybrid has higher CR's, even at 18 psi he would destroy a stage 2 sti. Now the real question comes up. Will his driveline be able to withstand the additional torque?
#15 |
Member#: 145658
Vehicle:On my 4th scoob and lovin it |
my 07 with fp 20g 8cm on 18psi would pull on a stage 2 sti no problems. I'd pull away slowly in the midrange but as soon as we got up in the rpm it was no contest.
#16 |
Member#: 184958
How about a 20G sti?
#17 |
Member#: 142345
Vehicle:2002 WRX 34'd WRB |
....... well i would say sti just because the tranny can handle the 20G to be pushed harder. Other then that, no clue. You have to be way more descriptive. Does the STi have built internals? Is it running stock injectors? Is it with meth and 25psi??? to many variables.
#18 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
#19 |
Member#: 122306
South East
Vehicle:2002 Sti PTE 6262sp Interlagos Blue 551/441 |
#20 |
Member#: 142345
#21 |
Member#: 175453
Vehicle:AE86 GT-S coupe i <3 alqonquin homosauce |
#22 |
Member#: 170432
SCIC
Vehicle:3076 Apollo Rotation |
You should be able to trap 120..
#23 |
Member#: 30367
South East
Vehicle:2005 Legacy GT NASA SE PTB Champ |
Srt-4
#24 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
300 lbs, powerband and gearing.....
really? pump gas 20g's in the 11's is common? links? yeah the 16 bit ECU licks ballz. The 300 g/s MAF limit and the 24.75 psi boost limit are pains in my arse. My HTA Green is maxing my MAF at ~5000rpm. The MAF problem can be worked around by getting a larger MAF tube and running a half MAF scale (IE 150g/s = 300 g/s and 300 g/s = 600g/s, basically just divide your whole MAF scale by 2, then divide all your loads by 2). The boost problem can be overcome by always running less than 24.75 psi or by rescaling the MAP sensor so 24.75 psi is actually something like 30psi....basically you just shift the whole MAP scale down by 5 psi so when the ECU says you're at 22psi your actually at 27psi....this allows you to run higher boost and still keep the boost limit fuel cut working. Last edited by Phatron; 02-23-2009 at 05:03 PM. |
#25 |
Member#: 137168
South East
Vehicle:06 Built SGM WRX 35r, PPG, 280's, PSS9. |
| Thread Tools | |
| Display Modes | |
| Stage 2 91 vs. Stage 2 93 | Rykenma | AccessPort | 1 | 12-14-2011 05:48 AM |
| protune stage 2 vs. stage 2.5 WRX | adWRXi | Factory 2.0L Turbo Powertrain | 15 | 03-06-2008 07:06 PM |
| comparison, stock buggy 07 Sti vs Stage 2 06 Sti | Xeno | AccessPort | 2 | 03-24-2007 06:28 PM |
| Stage 2 Sti Vs 2000 Porsche GT3 | Rsxkiller | Off-Topic | 61 | 10-03-2006 10:11 PM |
