Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 02-23-2009, 03:08 AM   #1
Member#: 155234
02 Wrx
Talking Help with rear crossmember!!!
I have a 95 impreza and i'm doing a rear end swap to a 03 wrx. now heres my question, can i just use the old x-member and just swap over the diff, links, sway,disc,brakes etc.... or do i have to use the 03 x-member with those parts?
The problem is that the way it bolt up is different from the new x-member.
Any pointers?
Never_Satisfied1 is offline   Reply With Quote
Old 02-23-2009, 06:10 AM   #2
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
How are the two crossmembers different? The bolt patterns for the chassis should be the same. Depending on the differential you intend on using, you may run into some fitment issues with the differential support if you don't change over to the '03.
beaviscih is offline   Reply With Quote
Old 02-23-2009, 08:15 AM   #3
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
You can use the old style rear cross member everything bolts up, but I recommend if you have it using the new one. They new cross member will have location on it for the relocated exhaust hanger of the MY02 and up, allowing you to use MY02 and up exhausts without not using a hanger or getting it modified. Plus rear bushing kits are more available for the MY02 up. Either way the existing bushings in the newer crossmember will be in better shape.
yebokmj is offline   Reply With Quote
Help with rear dust shields MaximusRex Brakes, Steering & Suspension 5 05-03-2002 11:52 AM
Need help with rear O2 sensor wiring diagram for 2000 Legacy GT jazzman Normally Aspirated Powertrain 1 04-17-2002 10:36 PM
Need Emergency Help with rear swaybar no_rex_yet Brakes, Steering & Suspension 4 10-25-2001 09:52 PM
('93-'01) need help with rear differential protector bryanw Impreza Forum 2 04-10-2001 12:32 AM
ATTN: All 93 - 95 Impreza Owners: Need help with rear seat questions! MrP0nch0 Interior & Exterior Modification 29 10-17-2000 10:14 PM
