Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-23-2009, 12:20 PM   #1
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Question turbo whine
Ever since I got my 04 BajaT (bought it with 58k miles) I've always noticed that the turbocharger whines quite a bit when it's pushing moderate to high boost.
Just recently discovered endwrench.com - great site for detailed mechanical stuffs for our Subarus! I found this article: http://endwrench.com/images/pdfs/UnderNov07EW.pdf
Aside from what I suspect is a cracked oil feeder line, is that whine sound a symptom of a turbocharger that's on it's way out? Check out the last page under Shaft Play at the above mentioned article.
moonzie is offline   Reply With Quote
Old 02-23-2009, 05:48 PM   #2
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
is it comepletely stock? a down pipe you'll hear the turbo whistle some more, even if its still running the stock cat back.
SubarusRmyThing is offline   Reply With Quote
Old 02-23-2009, 06:13 PM   #3
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
some do say that turbo 'whine's' like a supercharger before it goes out, but this isn't always the case. a rip in the inlet pipe can also lead to a 'whine' sort of sound.
Tahoe SC is offline   Reply With Quote
Old 02-23-2009, 06:32 PM   #4
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
There is something else that our cars are susceptible to: our turbo oil feed lines...one of them has a mesh screen that can clog and cause oil starvation.
This can shorten stock turbo life, the fix is to just cut the screen out. On a larger turbo, especially after market ball bearing units, the result is death of turbocharger within a couple thousand miles or less.
deadlydave is offline   Reply With Quote
Old 02-23-2009, 10:05 PM   #5
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Right, no aside from a K&N drop in, it's all stock.
I decided to get on it on my way home from work today and didn't notice nearly as much whine as I've heard in the past, so perhaps it's a bit random or weather dependent.
It still just smokes occasionally, not all the time - and lightly. Burning oil. And I know for sure it's coming from up under the turbo heatshield.
friggen cold miserable weather. Can't wait til bike-riding weather comes around again! Then I might be able to get some things done around here.
Old 02-24-2009, 05:29 PM   #6
Sefarious
Member#: 202894
2006 Baja Turbo
if you're burning oil make sure you check it every 100 miles or so. even a light every-once in a while smoke under boost can quickly drain your oil.
Sefarious is offline   Reply With Quote
I want to hear the turbo- whining about whine downwind4final Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 10-02-2006 10:51 PM
Turbo whine down noise peterlywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-04-2002 12:48 PM
Loud turbo whine / noice at idle Bill_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-13-2002 07:32 PM
Turbo Whine jaebusak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-29-2002 02:12 PM
how do i get really loud turbo whine? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-16-2001 12:28 PM
