Old 02-23-2009, 02:54 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default my car died... again!
i was in a parking lot. started my car..after like 1 min of idling, it just shut off..
i tried starting it back up...it cranks but doesnt start... i think its my fuel pump because usually i hear a little hummmm.... but i didnt hear anything..
i didnt do anything different..
I have:
95 impreza
94WRX(motor/tranny)
stock fuel pump. (95impreza)
im going to take out my FP and see if thats it... if it is, im going to get a walbro 255...
any other idea? im going to check it now... ill update my problem..
UPDATE:
-fump pump, forsure not pumping....might be relay or ECU
-not flooded
-i get 3.3v to the FP...
-checking if ECU is getting power (tomorrow)
-checking if the relay is broken (tomorrow)
-12v to ECu
-12v to the 3 relays under dash.
PROBLEM SOLVED
thanks for the help...
azn0boi04 is offline   Reply With Quote
Old 02-23-2009, 03:41 PM   #2
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Check engine light turn on when you turn the ignition key?
My guess is that you blew a fuse or relay and the ECU is not getting power.
-Rob
rob is offline   Reply With Quote
Old 02-23-2009, 04:19 PM   #3
luka
Member#: 194742
1993 Impreza WRX JDM
I had my pump fail on me, got a walbro installed as well.
take the back bench out to get to the pump it will save you a lot of aggravation when trying to pull the lines off the sending unit. (and be really careful they crack easy).
the easiest way to check for a bad pump is to pull a fuel line off the filter, turn the key to accessories for a split second and see if gas starts to piss out. I had a friend put his finger on the end of the return line to see if pressure built up but you can use a rag or whatever.
no fuel usually means pump went bye-bye. it could also be the relay. I'd use an LED or multimeter and see if you get any voltage when you turn the motor over at the pump. if you have power then yeah, it's your pump.
a faulty pump usually will give you rough starts and random stalls -- did you have any of those issues recently?
luka is offline   Reply With Quote
Old 02-23-2009, 05:34 PM   #4
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i unplugged the pump and used a multi meter on it... i only got like 3.3 volts... and when i tried cranking it... it went lower and lower... then back up to 3v...
where is the relay located?
Old 02-23-2009, 06:00 PM   #5
luka
Member#: 194742
you sure you probed the pump leads and not the send unit/gauge leads?
you should be getting 9v minimum.
and it's under the dash by the main relay way way in there you'll have to get on your back to see up there.
Old 02-23-2009, 07:23 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
o ok... those relays.. i know what you are talking about... i probed the plug that goes to the fuel pump... i unplugged it (from the rear, under that cover thing) and i rear 3v from there.... maybe it might be the relay... =
i hate those relays... it was easy to see with the dash off..
Old 02-23-2009, 07:26 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
first, verify the ECU is seeing power. Best way is to turn the ign on and see the CEL turns on. It doesn't matter if the FP and relay are in perfect working order, if the ECU isn't powering up, it will never trigger the FP relay to turn on.
-Rob
Old 02-23-2009, 08:05 PM   #8
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
no CEL...but something like this happened before (car flooded, somehow) no CEL then...
and when i used to misfire no CEL...i didnt do any recent modifications that would effect the ECU....
ill check if the ECU has power tomorrow..(raining, and homework)....
*what great timing, i was going to go to PR and see what my car does in the 1/4 mile...
Old 02-24-2009, 08:21 PM   #9
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i think it might be the relay... because i check the 3 relays under the dash (near steering wheel)and they all get about 12V.... i used the multi meter on the plug that goes into the relays...
i get 12v on the plugs to the relay... but only 3v to the FP...
ECU get 12V also...
Old 02-24-2009, 08:48 PM   #10
kingsubi
Member#: 19239
2011 WRX
the silver and green (4pin) is the fuel pump I believe. Brown is main relay (6 pin)
kingsubi is offline   Reply With Quote
Old 02-24-2009, 08:56 PM   #11
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ok... ill double check it... cuz i have an extra relay from the front clip i had... ill see if it does anything...
i used that extra relay on the other 4pin... let me try the green one.
Old 02-24-2009, 09:22 PM   #12
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ok.... weird... i unplugged ALL (3) the relays and i checked the FP plug... i still get 12v on the Green plug on the FP.!!!! OMG... i think im just going to order a walbro... i need it sooner or later...
input?!
Old 02-25-2009, 05:37 PM   #13
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ok well im going to get a new relay to see what happens.. and i ordered a walbro255 anyway...
i hope the relay does the trick...
wow.. i just called the subi dealer.... $42 for a dam relay....
Old 02-25-2009, 10:41 PM   #14
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
my guess is your main relay popped. If you don't have the CEL when the Ign swtich on, the ECU isn't getting power. This happened on Kaymin's car, I spent a few hours tracking it down. I can probably dig up a spare if you want to try it.
-Rob
Old 02-25-2009, 11:06 PM   #15
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
the main relay is the brown square one inbetween the 2 silver relays under the dash... right?
Old 02-26-2009, 11:26 PM   #16
kingsubi
Member#: 19239
2011 WRX
yes it is
Old 02-27-2009, 01:25 PM   #17
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well im going to the junk yard today to grab some relays... and maybe spare parts i can sell..
Old 03-01-2009, 09:35 PM   #18
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
And the problem was.........??
Old 03-02-2009, 01:30 AM   #19
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
BLOWN FUSE!!!!!!!!!!... also i think it was a combo with the relay...
well im getting my walbro in anyway.. and ill hit you up soon rob... about that chip...
Old 03-08-2009, 07:35 PM   #20
ibidu1
Member#: 204883
If it was a fuse, he wouldnt be able to get any power to the plug
ibidu1 is offline   Reply With Quote
Car died again :( jbwrx Mid Atlantic Impreza Club -- MAIC 29 12-27-2007 11:00 PM
Help! My car died today! WRX_Colin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 05-07-2002 04:08 PM
My car died 4 times upon starting it ToJo Normally Aspirated Powertrain 7 08-07-2001 11:18 PM
Why is my car dying on startup? TimCat Newbies & FAQs 16 03-13-2001 12:57 AM
