Old 02-23-2009, 06:03 PM   #1
EJ18
Member#: 87276
95 IMPREZA
BLUE
Default EJ22-T on a 95 ECU?
Im still in the part gathering phase, but im putting together a swap into my 1995 Impreza. I have the Legacy turbo engine, cross member, etc. But, im planning the engine management at this point and want to keep it cheap and simple. So, I want to try and run it on the original EJ18 ECU, in conjunction with additional injector controller, and a timing retard device like the MSD BTM. As ive had success with similar setups.
Im somewhat new to the Subaru world. So im open to constructive discussion on how I should go about this.
Sorry for the bad pic...
EJ18 is offline   Reply With Quote
Old 02-24-2009, 06:01 PM   #2
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
clean car i have a 95
Joshwrx04 is offline   Reply With Quote
Old 02-24-2009, 06:02 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
to keep it short and sweet, I don't think that will work.
XanRules is offline   Reply With Quote
Old 02-24-2009, 07:31 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Get an Emanage or a Perfect Power if you want to run a piggyback. Running several different controllers doesn't work so good...
Old 02-24-2009, 09:42 PM   #5
EJ18
Member#: 87276
95 IMPREZA
BLUE
That Perfect Power TF10 looks interesting... Thanks!
Old 02-25-2009, 11:16 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
where is slack .. he did the exact same thine .. 5-6 years ago
95 ej22 heads on a 97? Dual port goodness... Doncolberto530 Subaru Conversions 11 10-07-2009 04:52 PM
JDM WRX 95 ECU, which engine should I use it on? reddevil Engine Management & Tuning 2 12-16-2007 06:53 PM
My Ej22e Swap In my 95 Impreza I_got_a_SUBIE Newbies & FAQs 5 01-25-2006 03:53 PM
Has anyone done a 98 N/A EJ22 into a 93-95 EJ18 swap? Kostamojen Subaru Conversions 3 06-04-2004 11:40 PM
Wrx STi 95 Ecu Pinout Yellow_turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-30-2001 01:00 PM
