Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 02-23-2009, 07:14 PM   #1
newsubie1
Member#: 183595
04 Rex
Default Anyone running PE injectors instead of STI with OTS map
I purchased what was suppose to be STI "pinks" and received PE injectors instead. I called the vendor and was informed that these were like for like and would work with the COBB OTS map. The difference was at what pressure the injectors are tested at. PE tested at 38Ibs. and STI at 40Ibs. So PE rate at 510cc and STI at 565cc. This difference is due to testing pressure but apparently the same. Anyone using these PE injectors and having any issues? Thanks for any info./help.
newsubie1 is offline   Reply With Quote
Old 02-24-2009, 12:39 PM   #2
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /07 STI IS SOLD
PE INJECTORS are not the same as the sti injectors, the guy must be smoking crack .
I have PE 800cc injectors on my car and runs 100% idles 100%.
The key to setting up PE injectors is to have a tuner who knows what the hell they are doing ( AKA-proper scaling of injectors )
Make sure you find a tuner that has lots experience with PE injectors , otherwise they will never run wright.
tekfoc is offline   Reply With Quote
Old 02-26-2009, 04:48 AM   #3
EsubaruJ
Member#: 200008
85 AE86
01XJcrawler02WRXsold
Usually you want to stick as close the the map notes as possible. I would say its not a good idea to use those with the OTS map, however if you intend to use them the OTS map will probably be good enough to get you to a tuner
EsubaruJ is offline   Reply With Quote
Old 02-26-2009, 10:47 PM   #4
newsubie1
Member#: 183595
04 Rex
Well the PE injectors are being sent back in favor of Helix 820cc. Decided not to go with the VF34. Decided to go with EVOIII 16g and a map from surgeline tuning then make my way to portland for a tune.
Old 02-26-2009, 11:51 PM   #5
EsubaruJ
Member#: 200008
85 AE86
Nice. Hope it all works out for you!
PE injector installation of the clips ksp87wrx2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-18-2007 03:40 AM
anyone running 650cc injectors with an FP Green? wrxxed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 01-27-2007 06:14 PM
Can i run in DSP instead of SM w/ my CF hood? SpamMansXe Mid Atlantic Impreza Club -- MAIC 11 04-29-2003 04:07 AM
anyone regreted getting 17's instead of 18's (vice versa)? christurismohk Brakes, Steering & Suspension 23 10-15-2002 12:58 AM
Why are you guys running Redline75-90ns instead of mt90? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-28-2002 02:28 PM
