Old 02-23-2009, 11:45 PM   #1
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
Default my build will start finally
well just saturday my car decided it wanted to die on me, so instead of just buying a new shortblock i decided to build the block and go turbo. so here soon it will begin with the fun and tearing it all apart and building it all up. i will provide as many pics as much i can as i go along. i will be trying to do this on the cheap. i have already up/down pipes, turbo, emu, inlet, the basics to get started, i will actually give more details later. as it might change from now to then. i am just trying to do the most basic type build i can. i have a 16g that i will be using. i will also have this up so that i can ask questions as needed.
midnight2.5rs-t is offline   Reply With Quote
Old 02-23-2009, 11:56 PM   #2
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
So what other things you planning on?
turboed22 is offline   Reply With Quote
Old 02-24-2009, 12:23 AM   #3
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
maybe fmic some diff routing for the turbo just some small things really.
Old 02-24-2009, 03:57 AM   #4
master c
Member#: 168226
what pistons / rods you using?? i picked up some mahle pistons from extremepsi.com and i thought they were pretty damn nice
master c is offline   Reply With Quote
Old 02-25-2009, 03:12 AM   #5
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
thanks for the help i will check them out.
Old 02-25-2009, 03:30 AM   #6
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
i have been thinking about it all what i will probally try to do is use the stock rods and get them shot peened. i will throw on forged pistons and acl bearings.
Old 02-25-2009, 08:12 PM   #7
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
ok i have a boost amount i shooting for. i will be going 15psi on a 16g.
Old 02-27-2009, 08:10 PM   #8
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
^ So you are going to run WG boost?
Krang is offline   Reply With Quote
Old 05-10-2009, 03:25 PM   #9
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
i am going ewg but i kinda just wanna keep the trans for while is the only reason there for that.
Finally got my ej207, here is my build thread! Cyclops Built Motor Discussion 77 11-04-2009 12:19 PM
My 42r build...motor is finally done! texas05sti Built Motor Discussion 125 02-12-2009 02:55 AM
So Im finally starting my build..... kappathirteen Built Motor Discussion 10 12-20-2008 02:17 AM
My build, is finally done ! starace Built Motor Discussion 2 01-18-2008 11:42 AM
My build finally underway. *56k, do an engine swap* Harenil Normally Aspirated with bolt-on Forced Induction Powertrain 42 07-16-2007 12:35 AM
