Notices
Old 02-24-2009, 11:48 AM   #1
NicFunkadelic
Member#: 35330
1999 RSTi + 4.44 = )
Silverthorn... for now
Default STi swap done and runnig BUT clutch/flywheel dust shield issue
I just got my 07 sti swap running this past week, but discovered the horribly inconvenient fact that I bent the dust shield that covers the opening underneath the clutch and flywheel. I used a pry-bar to bend it out of the way of the rotating assembly, but I'm not happy having an exposed clutch and flywheel, and worrying that a little pebble could disable my car and cause damage. I'd hate to pull the motor for a stupid dust shield, but...
Is this shield replaceable? Should I replace it? Anyone know the part #?
Should I ghetto rig some home-made dust shield?
Any suggestions?
NicFunkadelic is offline   Reply With Quote
Old 02-24-2009, 12:42 PM   #2
NicFunkadelic
Member#: 35330
I know I'm not the first to do this, anybody have any input?
Old 02-24-2009, 01:37 PM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I would probably replace it for running in the wet, debris, etc as you mentioned. It's probably not critical but...............a wet clutch disc. I know it has a slit in it.
Is it possible to salvage the one you have? Beat it into shape?
I forgot to put mine back on . I looked and thought it would be difficult but doable with everything assembled. I know the 10mm head bolts are back above the crossmember, but I still think it's possible. gearwrench. I'll try tonight as I'm bored with other things on the car.
I may have an extra one, I'd have to look when I get home. Assuming they're identical.
It is replacable, I do not know a part #
If all else fails......duct tape.
I'm sure in this forum alone you could find a spare. I'm putting mine on and I don't even really DD the car.
mccanixx is offline   Reply With Quote
Old 02-24-2009, 02:08 PM   #4
NicFunkadelic
Member#: 35330
Thanks for the reply mccainxx. I actually just ran to the local suby dealership and ordered a new shield for around 20 bux. I probably could have just bent it back, but i doubt it would still do its job properly, because I think I mangled it pretty good. My RSTi is my daily driver, so I don't want to take any chances...
I'm going to attempt to just undo the motor mounts and hoist the motor and tranny an inch or two to install the new shield. I refuse to pull the whole motor out to replace that cheap little bastard piece of sheet metal. I don't think the new part will arrive till the end of the week, but I'll post an update this weekend when I attempt to slap it in.
Nick
Old 06-06-2012, 12:47 PM   #5
triniscoob
Member#: 143225
2004 JDM Sti
Nick
ANY CHANCE you got the OEM part NUmber on that sheild?????
thanks
triniscoob is offline   Reply With Quote
Old 06-07-2012, 12:13 PM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
You just bumped a 3 year old thread so the OP probably won't see this. What year, make, model do you have?
The part number for the Impreza is: 30216AA020 For the following dates:
'00, September — '02, May
'02, April — '02, December
'02, October — '04, March
geronimo81 is offline   Reply With Quote
Old 06-07-2012, 12:55 PM   #7
bisonjr
Member#: 102714
But, if you put in a 6-speed make sure you get one for an STi. The 5-speed shield will rub the flywheel.
bisonjr is offline   Reply With Quote
Old 06-07-2012, 02:47 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Seriously? A 3 year old thread about a stupid useless part? I throw those things in the trash, they are pain in the ass.
Old 06-07-2012, 03:14 PM   #9
bisonjr
Member#: 102714
lol... thats where mine is too.
NJ - Factory Sti Short shifter and AP Braided clutch line wrx/sti BuggeyEYED Drivetrain 20 04-20-2008 01:53 PM
Where to get an Sti swap done? 2000bluegts Subaru Conversions 2 11-16-2006 05:42 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 12:29 PM
I want an STi hood scoop and spolier..but where?? The Chef General Community 24 02-24-2006 08:12 AM
HELP!. swap done, and fuel pump wont fire supermoose Subaru Conversions 5 08-01-2005 06:39 AM
