Old 06-06-2012, 04:02 AM   #1
jdmjeb
Member#: 238534
2002 Bugeye
Default Need help with jdm ej207 identification
I was sent some pictures of a sti version "7" that I was purchasing and decided to run the identification numbers provided. The transmission code is ED-TY856WB3KA and the ECU id code is 22611AH581. It also has a serial number under the barcode 225122. I believe that this in fact a version 8. If anyone can help I would really appreciate it.
jdmjeb is offline   Reply With Quote
Old 06-06-2012, 02:31 PM   #2
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
That is a version 8 (03 STI) Twin scroll ECU code. I don't know about the trans code. Post up the pictures of the motor.. it'd help to identify it.
Computersare8ad is offline   Reply With Quote
Old 06-06-2012, 03:56 PM   #3
jdmjeb
Member#: 238534
2002 Bugeye
Thanks for getting back to me on the info. I was able to stop the error from occuring. Now they have sent me another pic of the ECU that they are going to send. The code is AF480 which is a version 7 sti ecu. The thing that worries me is that the serial number is 112200-7544. I have seen 41,41,45,46, and 48 in v7 ecu's but never 44 in the id number. Any ideas?
Old 06-06-2012, 04:09 PM   #4
jdmjeb
Member#: 238534
2002 Bugeye
Default jdm ecu id help!!
having trouble getting the pics to post but here is everything that I have on the new ecu
V8 in large bold in top center of id tag. Directly under that is a black line with the numbers 22611AF480. Under that is the numbers 112000-7544. The voltage of 12V is under that and finally a barcode with the numbers 207544..M? the last digit is unreadable.
Old 06-06-2012, 10:33 PM   #5
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
The big V8 stamp means it is a version 7 ecu, excellent work subaru design team.
But it doesn't really matter anyway since you can just flash the SD rom on it and be set.
lukeskywrx is offline   Reply With Quote
Old 06-07-2012, 02:26 AM   #6
jdmjeb
Member#: 238534
2002 Bugeye
Thank you for your help. Do you have any idea where i can find a table to decipher the rest of it? I guess i should be happy that at least now i'm looking at a v7? ecu. I can email a pic of it to you but for some reason i keep being told that the format of my photo is invalid. Oh well..
Old 06-07-2012, 11:03 AM   #7
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
Tranny code says its a 2003 STi W/DCCD http://forums.nasioc.com/forums/show....php?t=1225160
I believe V8 started in 2004 however some very late 2003 motors are also v8 motors. The twin scroll turbo and one piece red intake manifold is the big give away that its a v8.
Need help with JDM Beam Pattern AK*WRX*2004 Electrical & Lighting 2 08-19-2005 11:56 AM
need help with JDM HID's stu Electrical & Lighting 22 08-04-2005 11:27 PM
need help with JDM steering wheel Z0rr0 Legacy Forum 9 05-12-2005 08:21 PM
Need help with JDM mirror install on GC8 revel Electrical & Lighting 0 10-05-2004 11:17 AM
Need help with JDM headlights DJDaizzy Interior & Exterior Modification 8 11-16-2002 06:18 PM
