Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 04-09-2002, 12:43 PM   #1
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
Default what to buy? low compression pistons or short block?
I was thinking about this on my way back from class today because Im turboing my RS and seeing that my kit is not doing much good sitting on my couch I wanted to see what the better route would be. I have a 98RS so keep that it mind. Would it be a better idea to get low compression pistons or just I just go the whole nine yards and bolt the 2.2 block to the 2.5 heads. What would be the better plan both cost wise and effectiveness? I dont want to blow up my car so Im taking all the precautions BEFORE my turbo kit goes on! Thanks for the help guys like always
Kyle
98RS Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 04-09-2002, 04:14 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Remember that your engine is a little better for turbocharging due to the fact that your engine comes from the factory with 9.7:1 Compression pistons. This will be better to handle boost. Although, the Phase I blocks didn't have the best head gaskets, and this seems the most common problem with MY98 turbo owners having troubles.
As far as cost effectiveness, the pistons will run you anywhere from $700 and up. Not many (if any at all) places stock pistons for our cars due to the low amount of purchases, so plan on waiting a while for them. You can also tack on a pretty penny for the install of these things, and if it was me, I would do rods while I was in there.
You won't absolutely need low CR pistons to run boost, just don't go crazy. I say keep it conservative and you won't run into any major problems. One thing though, you MUST have some sort of timing control.
Graham
Graham is offline   Reply With Quote
Old 04-09-2002, 07:16 PM   #3
adamsrs
Member#: 3768
I have a set of JE 8.5:1 compression pistons, rings, and pins for sale. BRAND NEW!
adamsrs
adamsrs is offline   Reply With Quote
Old 04-09-2002, 09:36 PM   #4
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
would the Apex-i ITC be suffcient for timing control?
Kyle
98RS Owners UNITE!
Old 04-10-2002, 02:15 AM   #5
kaos200
Member#: 2692
Arrow
adamsrs
Adam your pistons will Not work on his motor. Why are you selling?
kaos200 is online now   Reply With Quote
Old 04-10-2002, 02:31 AM   #6
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
there is a very wide price gap between the two also. Pistons go for around 800 and i think a block would go intot he thousands. I would go for the pistons since you have the 98 block. They seem to handle boost better than the my00 plus
Andy
ac_gohan is offline   Reply With Quote
Old 04-10-2002, 11:09 AM   #7
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Smile
I think blocks are somewhere around $1200-1400. Since you have to pull the engine either way, you will pay the same labor for that side of it. With new pistons you have to pay to have the old pistons pulled, the block bored for the new size pistons, and then the pistons installed. If you do rods as well there will be more costs for machining, balancing the crank etc.
The cost is pretty close in my opinion.
Keep in mind almost everyone who has aftermarket pistons complains about how loud they are, so if that will bother you may be better off with a 2.2 motor.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 04-10-2002, 11:31 AM   #8
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Originally posted by AaronB
[b]
Excuse my ignorance, but what makes them loud?
-Nathan
crash is offline   Reply With Quote
WTB OR, PNW: STi EJ257 .020(100mm) over Wiseco pistons, or short block w/.020 pistons outback2.5HO Private 'Wanted' Classifieds 3 07-24-2009 02:56 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
low compression pistons? SoobATV Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-18-2001 04:03 PM
a 450hp turbo w/ low-compression pistons?? what happens to the power??? FuJi K Normally Aspirated Powertrain 7 03-06-2001 08:22 AM
What to buy? '01 Brighton Wagon or OBS? or wait for '02? Garvinator General Forum Archive 11 12-15-2000 12:55 AM
