Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 02-25-2009, 02:33 AM   #1
mc2
Member#: 59992
1997 Legacy L EJ22
Default What's the solenoid just above the charcoal canister?
There's a hose that Ts off of another hose on my charcoal canister which runs up to a solenoid located just above the charcoal canister. Can anybody tell me what solenoid that is? Looks flat/roundish.
It's actually on a Legacy, but i suspect it's similar on all subarus.
mc2 is offline   Reply With Quote
Old 02-25-2009, 02:40 AM   #2
mc2
Member#: 59992
1997 Legacy L EJ22
Actually, based on some diagrams i think it might be the Pressure Control Solenoid Valve.. does that sound right?
What purpose does that valve serve? What would happen if the hose that T's off of the "Drain" leading back up to that valve was broken?
Old 02-25-2009, 03:32 PM   #3
Annapolis Subaru
Member#: 107051
your right, it is a solenoid. subaru calls it a vent control solenoid valve. it's purpose is to vent air into the fuel/evap system to keep the system pressurized correctly. if the hose leading from the valve is busted you may not be keeping the correct pressure in the system, normally the valve brings air from the atmosphere into the system to balance the vaccum within, due to the excess fuel vapor being vented elsewhere. usually any problem around there will throw a check engine light.
-subaruidiot101
Annapolis Subaru is offline   Reply With Quote
Old 02-25-2009, 03:38 PM   #4
mc2
Member#: 59992
1997 Legacy L EJ22
Thanks. Car hasn't thrown any CELs, i just have a problem with the pump clicking off all the time when i try to fill gas.
Iridium spark plugs - is the iridium just on the very tippy-tip tip Carlito2002WGN Newbies & FAQs 5 03-12-2010 12:14 PM
Heh, the news just played the F word twice. Vostok 7 Off-Topic 9 01-01-2007 12:16 PM
Looks like the Vortex just discovered the STi in Ice kage Off-Topic 13 01-04-2005 02:38 PM
Is the coolant level above the top radiator hose when cold? mtb_dude Service & Maintenance 2 03-23-2004 08:06 PM
Geee, the Pats just beat the Jets 44-7 KC Off-Topic 35 10-06-2002 08:37 PM
