Old 02-25-2009, 06:19 AM   #1
jaimebenlasnow
Member#: 188065
Default Question about swap.
So i'm doing a swap soon of a 93 EJ20G in my RS
I got alot of question concerning the swap.
1.So for the wiring do i have to rewire the whole car? like changing all the fuse box and all these things?
2.Where to get replacement hose?
3.Can i just buy a straight inlet turbo then buy a 90 sillicone inlet?
4.Do i need to replace my radiator for a slimer one in aloy? (Like the cxracing one)
5.I'm going FMIC, I've read somewhere that we need to relocate the coolant tank?
6.For CAI, what are my option?
7.And i'm thinking about trying the ESL live map thing? does anyone already tried that?
jaimebenlasnow is offline   Reply With Quote
Old 02-25-2009, 06:38 AM   #2
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
1. the majority of the car has to be wired and extended when merging the harness.
2. ECS sells and merges harnesses
3.you can do the straight inlet turbo, a few guys on here have a VF series and whatnot with a 90 degree tight radius coupler.
4.you can use your stock radiator, it is 100% fine
5.the coolant tank does have to be relocated, bc the charge pipe goes right down where it used to sit, right beside the radiator fans and the timing belt cover on the drivers side.
6.for the ej20g, apexi makes a kit designed for this motor, and for the 90 degree inlet on the turbo, comes with everything.
7.ESL?? never heard of it,b ut from the sound of it, kinda sounds like the maps are down loadable, kinda like chrome on turbo hondas, i would try to stay with something alot more users have and give good feedback on.
gc8awdsti is offline   Reply With Quote
Old 02-25-2009, 07:07 AM   #3
jaimebenlasnow
Member#: 188065
1.So what do i have to merge and what do i have to not merge?
2.I'm talking about radiator hose and all these things are they universal for 93-2007?
5.How do i relocate that? how did you do that bro?
Old 02-25-2009, 12:21 PM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
1) There are ways to do the wiring were you do not need to extend any of the harness and you don't need to redo the entire RS wiring. I have done the wiring prep for a few members here if you want to consider sending it out.
2) What kind of hoses? There are Samco kits for nearly all of the coolant hoses.
4) I wouldn't recommend the stock radiator just out of principle.
7) The "Live Map" name is a misnomer. They only allow remapping capability to vendors in the UK, not to individual users. I can help with a chip upgrade for more boost and a better tune if that's all you are after.
-Rob
rob is offline   Reply With Quote
Old 02-25-2009, 04:08 PM   #5
jaimebenlasnow
Member#: 188065
1) You've pmed me
2)I'm looking for pretty much all the hose on the motor they are all cut.
3)So, i should buy one of those ebay alloy rad?
&)Just curiosity, Why are they capable to live map and we're not.
Old 02-25-2009, 07:15 PM   #6
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
you need the heater hoses that were cut, you cna use your stock rs ones. as for radiator hoses, you can pretyt much go to the auto parts store and just pick the ones that bends the right way bro.
Old 02-25-2009, 08:29 PM   #7
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
for my coolant tank i just got some hose from Schucks (autoparts store) and bent it to fit (suppose to be straight)..
the curves are good, no pinching..
azn0boi04 is offline   Reply With Quote
Old 02-25-2009, 11:32 PM   #8
jaimebenlasnow
Member#: 188065
And what do i do about my FMIC?
Where do i relocate the coolant tank?
Old 02-26-2009, 02:39 AM   #9
Aphex28
Member#: 11506
2015 WRX
Just look at pictures of other people's FMIC kits to get an idea of what to do. It's not hard at all.
If you want OEM, there is an inside-the-driver's-fender-tank that came on older model wrx's. I got lucky in finding mine. Autozone also sells a tank and hoses that will relocate it but this is only marginally better than a soda bottle.
Aphex28 is offline   Reply With Quote
Old 02-26-2009, 01:10 PM   #10
JDMG3
Member#: 137792
1997 Legacy Outback
Green
i have done a EJ20K in my 97 legacy and as far as wirring gors it was time consuming but easy. I modified the stock engine harness to fit the engines sensors and then I cut the harness at the ECU and soldered the wires to the EJ20K ECU plugs.
JDMG3 is offline   Reply With Quote
Old 02-26-2009, 02:12 PM   #11
luka
Member#: 194742
1993 Impreza WRX JDM
do you have the entire wire harness/ECU with your motor?
when I did an S14 SR20DET into an S13 I used the entire S14 harness and the only modifications I had to make were wiring the Tach, CEL, and some other dash warning lights and the power relay to the ECU. it was like 8 wires total. Saved myself a lot of hassle doing it that way instead of trying to mate two different harnesses.
accessories (lights, starter, ignition) are separate from the motor so you shouldn't worry about that junk.
And piping/FMIC, that's where you get to show your creative side
if you can't find a stock canister just make one or take one from any random car as long as it fits in your bumper or wherever you want to put it you're groovin.
or, even better, haha, run your charge pipe through it, then you'll have FMIC and water cooled
luka is offline   Reply With Quote
Questions about swapping ECUTEK ECU's B16A2NR Engine Management & Tuning 3 01-22-2006 09:43 PM
Questions about swapping jdm Norcalrallyist Subaru Conversions 9 01-19-2006 05:10 PM
question about swapping a 2.0 for a 2.0 BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-25-2005 02:39 AM
Questions about swapping in V4-V6 5mt's into V7. AZScoobie Transmission (AT/MT) & Driveline 4 12-29-2003 08:23 PM
Question about swapping in JDM EJ20 turbo engine and gasoline requirements edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2001 11:39 AM
