Closed Thread
Old 02-25-2009, 05:35 PM   #1
!kid
Member#: 187746
08 WRX 4door
satin white pearl
Default turn signal problem 08 wrx
my car is all stock i have never messd with the wireing
i am have a funny problem with my turn signals but it does not happen all the time
my right turn signal will blink fast but both bulbs are working also left,right front and real turn signal bulbs are dim but like i said its not like this all the time is any one else having this problem in there 08
car has 4960 miles on it
!kid is offline
Old 02-25-2009, 06:10 PM   #2
1stockwrx
Member#: 162365
06 RSX Type S
dealership.
1stockwrx is offline
Old 02-25-2009, 06:51 PM   #3
Jncominco2
Member#: 170212
if its under warranty, take it to the dealer
Jncominco2 is offline
Old 02-25-2009, 06:55 PM   #4
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
could be a bad tun signal switch or bad flasher. dealership.
jdubya301 is offline
Old 06-13-2009, 08:58 PM   #5
papafrito
Member#: 181280
2008 WRX-Prn STG 2.5
Dark Gray Metallic
+1 Stealership.
papafrito is offline
Old 06-14-2009, 04:52 PM   #6
Jowie
Member#: 193291
2009 WRX Sedan
I'm assuming the OP got this fixed since its been quite a few months since the original post. But I'd figure I'd chime in since I had a similar issue with my car brand new.
I have a 09 and had an issue where my right turn signal would flash fast, but only when the car had sat over night. Once the car had warmed up the issue went away. Strange right? I went out and saw that the culprit was the front passenger side turn signal. To fix it, all I did was take out the bulb and re-seat it back into the socket. Haven't had the issue since. I suspect an intermittant contact that fixed itself once the connector parts had warmed up enough and expanded.
Jowie is offline
Old 06-15-2009, 07:38 PM   #7
BoostGtzULyd
Member#: 214158
Sounds like a connection problem from the bulb end to me, as well. I just bought an 09 so if I tend to have the same issues I'll know what to look out for
BoostGtzULyd is offline
Old 07-16-2009, 09:21 PM   #8
Blackout33
Member#: 179361
1999 corvette
i'm having the same problem did u end up taking to the dealership or did u fix it yourself.
Blackout33 is offline
Old 07-20-2009, 04:32 PM   #9
Jowie
Member#: 193291
2009 WRX Sedan
I ended up fixing it myself. All I did was take the bulb out of the socket and put it back in. Still haven't had any issues with it since. Its a pain to get to though. I ended up taking the airbox out of the car to get better access to the passenger side front turn signal. I've heard there is a way to get to it from under the car, but at the time I didn't know this, and I haven't checked since. I plan to get back in there soon though so I can disable the DRLs, since the connector you need to unplug is in there.
As everyone else said though, if any of this sounds like too much trouble, take it to the dealer, you should still be under warranty if its an 08 or 09...
Jowie is offline
Old 03-19-2011, 02:20 PM   #10
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Sorry for bumping an old thread, this is what came up in my search.
I have a 2011 WRX and starting at about 800 miles the right turn signal started having issues the same as the OP. The rear turn signal would blink really fast and the front one would blink really fast but not very brightly. This problem would be there for a few days then go away for a bit then come back again.
I brought my car to the dealership while the turn signal was working. Basically I made an appointment three days before and the night before I brought it there the turn signal started working. They spent hours and said they couldn't find anything wrong with it.
I drive my car home and what do you know, when I put on the signal to turn onto my street it starts doing it again! I was pretty pissed so I decided to fix it myself. The problem is the actual wires that plug into the harness. There is so much tension in the way the wires were wired from the factory that they pull out a little bit from the harness, making the connection very poor.
To fix it, I physically pushed the wires back into the harness and then undid the way the wires were wired from the factory. This eased the tension in the wires so they don't pull out anymore. To reach the wires I had to remove the airbox, which was really annoying to take out but besides that it was pretty easy.
mrkyle3 is offline
Old 03-30-2011, 03:14 PM   #11
funnotc02
Member#: 166942
2012 WRX STI 4 Door
I will have to give that a try. I am getting the same issue with my 2011 STI but on the driver side. It has just over 2,000 miles on it and it just started up yesterday. At first it would do double time and then slowly go back to normal but after driving for a while it just began to stay fast.
funnotc02 is offline
Old 06-11-2011, 02:29 PM   #12
ammodawg79
Member#: 267366
2012 Sportage SX
Black Cherry
Glad I didn't start a new thread about this.
My 2011 WRX is doing the same thing, left blinker goes really fast and dim, then magically starts working normally again. This issue just came up. Naturally I checked the bulbs, but both front and rear seem to be working. Guess I will take it into the dealership since it is obviously under warranty.
I would give the suggestions here a whirl but honestly, a car with 5k miles shouldn't have this issue and Subaru made reaching the bulbs a real PITA without tools (on vacation so no tools). I am starting to hate newer cars, seems as if manufacturers make everything a pain to do on them on purpose so you have to go to a dealer.
ammodawg79 is offline
Old 08-21-2011, 08:25 PM   #13
veacomp
Member#: 131479
2006 WRX Sportwagon
I just purchased a 2011 STi. I have 250 miles on it and this issues just showed up. Did a search and found there is a TSB about this. I will be bringing my car in to get this fixed.
Vehicle: 2011 Subaru Impreza
Nature of Defect:
EXTERIOR LIGHTING:TURN SIGNAL
Bulletin Number:
SB-0708
Bulletin Date:
Jan 2011
Summary:
SUBARU: TURN SIGNALS MAY BLINK TOO FAST DUE TO TENSION IN THE BULB SOCKET WIRING. 2008-2011 IMPREZZA. ( NHTSA ITEM NUMBER - 10038287 )
veacomp is offline
Old 08-28-2011, 05:00 PM   #14
S2baru2
Member#: 292247
2011 STI
Dark Grey
Default Me too
Really glad I found this thead. My 2011 STI has this problem. 125 miles. Will call dealership.
S2baru2 is offline
Old 09-18-2011, 01:01 PM   #15
1stSubi
Member#: 292107
I had this same issue come up with my 2011 Impreza, right after I installed wiring for a trailer, so I thought I must have done something wrong. Finally got to the front blinker bulb, took it out, put it back in, and the problem went away.
But WAIT, theres MORE!
Now my check engine light is on, my cruise control light blinks, and my traction control light is lit, indicating that it's turned off.
Any ideas! I looked all around the air box to see if I dislodged any plugs or wires, but I don't see anything obvious.
Throwing codes p0102 and p0113. I'm thinking maybe since I had the key in the on position while playing with the signal, and the MAF unplugged maybe that's what threw the codes. I just reset them so I guess I'll find out.
1stSubi is offline
Old 09-19-2011, 07:42 PM   #16
alextheman
Member#: 87703
2011 WRX
Grey
I too am having the turn signal problem. It is my driver side front signal, it works just is very dim and is blinking rapidly. This is a 2011 WRX. Do I have to remove the battery to get to the bulb to "re-seat" it and potentially fix it? If not, what is the quickest/easiest way to get to that? Thanks in advance.
alextheman is offline
Old 09-19-2011, 07:49 PM   #17
Strainjah
Member#: 291262
2011 Sti Hatch
Plasma Blue Pearl
I have a 2011 Sti hatch with 4500 miles on it. I replaced the passenger side turn signal bulb twice in 3000 miles. At first oil change I informed the dealer and they replaced the wiring harness under warranty. Take it in and let them deal with it.
Strainjah is offline
Old 09-19-2011, 07:51 PM   #18
alextheman
Member#: 87703
2011 WRX
Grey
Which wiring harness are you talking about? I recently switched out the deck in my car and I don't want that to be the cause of this and have the dealer do something to my warranty. Is the harness anything to do with what is behind the deck? I also added a steering wheel control harness to my car when I did the deck and don't know if this could have anything to do with it.
Old 09-19-2011, 09:26 PM   #19
S2baru2
Member#: 292247
2011 STI
Dark Grey
The dealer repaired my problem today. "Tech repaired contact in left turn signal socket" was stated on the work order. Took them .2 units (hours?).
S2baru2 is offline
Old 09-19-2011, 11:02 PM   #20
crismon22
Member#: 288010
2006 wrx
red
i have an o6 wrx and my illuminations light will not turn off and the fuse isnt blown but the dealer hasnt called me back yet
crismon22 is offline
Old 01-17-2013, 11:54 AM   #21
Mr.Anderson
Member#: 200857
2013 FX4 EcoBeast
have this same problem with my 2012 sti.. so annoying
Mr.Anderson is offline
Old 01-17-2013, 01:59 PM   #22
Scanyland
Member#: 282593
1996 Subaru Legacy
Thread is 2 years old
Scanyland is offline
Closed Thread
Help on Replacing Front Turn signal bulbs: 08 Impreza WRX TheSickDoctorCE Interior & Exterior Modification 7 10-14-2014 05:24 PM
Brand new Non fog light turn signal switch 08 to 10 Dereksti Interior/Dressup/Audio & Security 27 01-21-2010 04:17 PM
Cleared Headlight Turn signal Problem.. urabusXRW Electrical & Lighting 2 01-24-2006 10:22 AM
Tai light / turn signal problem, Help... WRXplatinum Electrical & Lighting 1 07-07-2005 09:50 AM
Turn signal problems...some help Herojin Electrical & Lighting 10 09-28-2004 06:50 PM
