Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 02-25-2009, 08:51 PM   #1
elsuicida
Member#: 189889
02 Bug-Eye Stroker
*Twin Scroll Equipped*
Default Do you have to remove the timing belt to change water pump?
Im changing my water pump, do you have to take out
the entire timing belt, or can you sneak it through.
I dont want to mess with the aligments of the gears
and what not...
elsuicida is offline   Reply With Quote
Old 02-25-2009, 08:55 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I did you a favor and edited your title. In the future, the title is there so people have some idea what they're clicking, please use it properly and don't use text-message language. Thanks
Audiosavvy is offline   Reply With Quote
Old 02-25-2009, 09:19 PM   #3
big16gwrx
Member#: 129459
play it safe and remove the belt and mark all the positions of the cam cogs
big16gwrx is offline   Reply With Quote
Old 02-25-2009, 10:49 PM   #4
mmaurini
Member#: 165039
2002 WRX w/ 16g
I would be extremely worried about removing the water pump and keeping everything aligned. Also, I don't see how you will be able to reinstall the tensioner without completely removing the t-belt to compress and re-pin the tensioner before the reinstall.
Check you timing marks before and after pulling the pin on the tensioner.... I'm speaking from experience on that one.
-Marc
mmaurini is offline   Reply With Quote
Old 02-26-2009, 01:09 AM   #5
mrdrd04rex
Member#: 203051
2009 Outback
Tbelt has to come off my friends sorry. Trust me. I work at a dealership, and we do pumps weekly.
mrdrd04rex is offline   Reply With Quote
Old 02-26-2009, 02:04 PM   #6
elsuicida
Member#: 189889
02 Bug-Eye Stroker
How much does the dealer usually charge to do a
water pump...I mind as well do the T-belt too.
Old 02-26-2009, 02:12 PM   #7
Audiosavvy
Member#: 150794
Qcab dakota 4x4
They are all different. Call them and see.
Old 02-26-2009, 05:11 PM   #8
mannslayer
Member#: 94978
Lots. The dealer will usually do the water pump and replace the t-belt at the same time.
mannslayer is offline   Reply With Quote
Old 02-27-2009, 04:24 AM   #9
highway_patrol
Member#: 154296
Slow as balls
Ford Ranger
I know that dealerships vary but I was quoted around 750 for timing belt water pump and new thermostat. I did the belt and pump with the help from a friend for ~300 parts and gas to drive there. It took about 2 hours. See if there's somebody in your area that would be willing to help.
highway_patrol is offline   Reply With Quote
Used Parts / yard sale: Prodrive EBCS, ej257, timing belt tensioner and Water Pump @@ IA Performance Engine/Power/Exhaust 1 08-03-2009 12:13 PM
105k-mi service. Timing belt chg w/ Water Pump, Idler, Harmonizer? dcwrx2 Service & Maintenance 31 03-09-2009 03:53 PM
Timing Belt Tensioner & Water Pump sciroccokid NESIC Private Classifieds 1 10-25-2008 01:28 AM
Need Help! Timing belt, tensioners, idlers, water pump, crank/cam seals dhjester Service & Maintenance 4 08-23-2008 10:48 PM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 07:33 PM
