Vancouver Impreza Club
Old 02-25-2009, 11:16 PM   #1
ex_boyometric
Member#: 165210
2014 WRX STi Tsurugi
Default Tire Pressure Problem
For some reason, my front left tire loses it's air pressure really fast while my other tires are fine. Even when I rotate the tires, it's still the front left so it doesn't look that one of my tires is leaking. Anybody has any idea why this is happening?
ex_boyometric is offline   Reply With Quote
Old 02-25-2009, 11:21 PM   #2
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
Hit the treadmill?
shawmacs is offline   Reply With Quote
Old 02-25-2009, 11:23 PM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
How fast is fast.
alcoolaid is offline   Reply With Quote
Old 02-25-2009, 11:41 PM   #4
ex_boyometric
Member#: 165210
Lose 5.5PSI in 1 month
Old 02-25-2009, 11:43 PM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Check the tires that are losing air. Most likely punctured.
edit: check the valve stems too
Old 02-25-2009, 11:49 PM   #6
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
My left front is losing pressure at about that speed as well. I suspect valve stem.
Old 02-26-2009, 12:02 AM   #7
ex_boyometric
Member#: 165210
Maybe valve stem.... but the thing is, before i did my tire rotation it was the front left that's losing air fast, and after i did the tire rotation it's still the front left that's losing air fast. The tire that got swap to the back didn't even lose air pressure when it lost pressure when it was in the front. The tire that was in the back initially that got swapped in the front, it wasn't losing air when it was on the back either.
Old 02-26-2009, 12:42 AM   #8
alcoolaid
Member#: 134949
'07 SWP STi
Did you do the tire rotation? Just asking...
Old 02-26-2009, 12:45 AM   #9
ex_boyometric
Member#: 165210
Yep..... I did.
Old 02-26-2009, 12:47 AM   #10
alcoolaid
Member#: 134949
'07 SWP STi
Oh well... it's losing air some how. Are your pressure checks in the same conditions?
Temps can change a lot before and after driving.
Old 02-26-2009, 01:21 AM   #11
ex_boyometric
Member#: 165210
Uh huh...
Old 02-26-2009, 01:42 AM   #12
LilDragon
Member#: 203913
1999 2.5 RS Sold :(
WRBlue & Rally Tattoo
Maybe try to switch the rims? I mean put either rim from other three on this tire,n see what's happening.
LilDragon is offline   Reply With Quote
Old 02-26-2009, 01:49 AM   #13
ex_boyometric
Member#: 165210
I think I will just do a soapy water test and go from there
what tire pressure to run stock? and what is a good aftermarket tire? jay25RS Tire & Wheel 6 06-13-2011 01:54 PM
Tire pressure Noek Newbies & FAQs 5 06-04-2010 01:25 PM
New tires, which tire pressure to go by, tire or car? NewShockerGuy Tire & Wheel 7 12-04-2004 02:33 PM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
Tire Pressure for snow tires??? 99 RS 2.5 New England Impreza Club Forum -- NESIC 4 10-12-2000 09:17 PM
