Old 02-26-2009, 11:30 AM   #1
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Default GT35R, Raw Performance Signature Package, Pump/Meth
All runs in 4th gear. 22psi of boost on mbc with 93 pump and 51/49 mix of methonal. 87% Injector Duty Cycle.
Current Mods:
Engine:
Raw Performance/Axis Racing Signature Series Shortblock:
2.5L Block
Darton Sleeves
Modified Crank (Better Oiling)
Custom Pauter Rods
Custom CP Pistons
High Performance Piston Rings
Balanced & Blueprinted
Cometic Head Gaskets
Greddy Timing Belt
Raw Performance/Axis Racing Signature Series Head Package:
Kelford 280/276 Custom Grind Non-AVCS Camshafts
Supertech Oversized Valves
Supertech Dual Valve Springs
Valves Lapped
Titanium Retainers
Shimless Buckets
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Flow Bench Tested
Perrin Rotated GT35R Turbo Kit (.82 2.5" Outlet)
Perrin FMIC
HKS SSQV BOV
Power Enterprise 850cc Injectors
Dual Walbro 255lph Fuel Pumps
NGK Iridium One Step Colder Spark Plugs
NRG Grounding Kit
Hallman MBC
Megan Racing Radiator
Moroso Oil Catch Can
AEM Meth kit
Hydra EMS
DRIVETRAIN:
JDM STi 6spd LSD Non-DCCD Transmission
R180 Rear Diff
STi Axles
South Bend DXD Clutch Kit
Perrin Shifter Bushings
Kartboy Short Shifter
Intake/Exhaust:
Perrin Rotated Intake Kit
Greddy Ti-C Catback
Perrin Down Pipe
Perrin Equal Length Header
Exterior:
STi Fog Light Covers
Rota Group A 17" Rims
Bridgestone Potenza RE01-R Tires (SpringSummer/Fall)
Kumho Ecsta ATX Tires (Winter)
30" Tint by Shades of Gray
Interior:
Corbeau Forza Race Seats
Autometer Boost/Vac Gauge
Suspension/Brakes:
Megan Racing Coilovers
Perrin Subframe Stabilizer Bushings
JDM STi Front & Rear Strut Bars
Rallitek Front & Rear Sway Bars
Subaru 4-Pot Front Calipers
Powerslot Slotted Rotors
Brembo Rear Calipers
Hawk HPS Brake Pads
Tuned by Andy @ Verocious Motorsports
Huff is offline   Reply With Quote
Old 02-26-2009, 11:51 AM   #2
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
What are the numbers for those who can't see pics and graphs at work?
kellygnsd is online now   Reply With Quote
Old 02-26-2009, 11:52 AM   #3
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Wow man, great job with the car, def a very nice set up. With these supporting mods, do you ever plan on getting larger injectors and turning her up to 32-34psi?? You'd def be in the 600+ club.
Congrats,
-Mikey
STi Mikey is offline   Reply With Quote
Old 02-26-2009, 11:55 AM   #4
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
473whp 452 tq
Old 02-26-2009, 11:55 AM   #5
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Congrats,
-Mikey
Yeah I plan on running secondary injectors with APS TGV's and custom fuel rails and lines.
Old 02-26-2009, 12:20 PM   #6
Badler
Member#: 133597
Nice #s. Engine bay pics?
Badler is online now   Reply With Quote
Old 02-26-2009, 01:12 PM   #7
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Im suprized the power is falling off up top with those cams.. Good numbers none the less..
bigmike25rs is offline   Reply With Quote
Old 02-26-2009, 01:15 PM   #8
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Reason being its a .82 hotside and a 2.5" outlet. Once I switch to a full 3" outlet and a 1.06 hotside it'll hold to redline much better.
Old 02-26-2009, 01:32 PM   #9
e[tx]
Member#: 182437
04 STi
Wrb
If you make a car this badass, seriously, pictures or a video at the least, dyno plots are just like the fat of the bacon..
e[tx] is offline   Reply With Quote
Old 02-26-2009, 02:12 PM   #10
bboylocob
Member#: 151809
2007 WRX
turn up the boost the engine is dieing for you to open her up!!!!!
bboylocob is offline   Reply With Quote
Old 02-26-2009, 02:18 PM   #11
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Hotside I disagree with. Tial .62's are holding more tq up top with cams. It should be much much flatter.
How much boost are you holding at redline?
CoolRex is offline   Reply With Quote
Old 02-26-2009, 02:20 PM   #12
BuggeyEYED
Member#: 101691
09 G37x coupe
SOLD - 35r bug/hawkeye
sleeved with rods etc etc..id def put the 1.06 unless its a daily driver..i had to switch back to the .82 myself
BuggeyEYED is offline   Reply With Quote
Old 02-26-2009, 02:21 PM   #13
BuggeyEYED
Member#: 101691
09 G37x coupe
sleeved with rods etc etc..id def put the 1.06 unless its a daily driver..i had to switch back to the .82 myself...although i dont really daily it..i shouldve kept it /:...[/
Old 02-26-2009, 02:25 PM   #14
4ST-AIR
Member#: 148681
2007 0-60 in $65,000
SOLD!!SOLD!!SOLD!!SOLD!!
Ron builds the best SB/LB combos in the US hands down. 22psi on METH and 93 thats some awesome numbers.
Nice Build!
4ST-AIR is offline   Reply With Quote
Old 02-26-2009, 02:39 PM   #15
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
Obviously the setup is running out of fuel, or close to it (idc). So he decided to chill out and stop where it is currently. IMO its probably pretty freaking fast for a DD (had a childs seat in back seat) and more importantly... no doubt reliable with that tune but on the edge to start breaking drive tran parts if driven to 'poorly'. IMO Its a VERY nice amount of TQ also.
More fuel and more boost FTW!!!
If you end up following me to MD on saturday for my retune, we will do a few pulls on the way home,ha.
me=110oct
you=93oct, no meth
bet you still pull on the sti...lol. Just wait for my zo6 one day...lol.
c'dalerider is offline   Reply With Quote
Old 02-26-2009, 02:42 PM   #16
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
From talking to my tuner and engine builder the 1.06 is the way to go to keep the power up in the upper rpms. This is my daily driver til I get a new job. The car will be staying at this power level until the next fuel setup and turbo housing is put on. No reason to exceed 87% duty cycle.
Old 02-26-2009, 02:47 PM   #17
bboylocob
Member#: 151809
2007 WRX
agree with you on that. but once you get the the new 1.06 i better see some friggin awsome butt rippin power
Old 02-26-2009, 02:48 PM   #18
Teh Legacy
Member#: 9853
to keep your mouth
shut.
You're a fool if you don't get bigger injectors and turn up the wick. That's a 600 WHP setup if you provide the fuel.
Teh Legacy is offline   Reply With Quote
Old 02-26-2009, 03:52 PM   #19
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
Wow thats some power for that low of boost.
Im not going for that kind of power but ill have one of Rons block and head packages in soon. but not as aggressive 276/272 kelfords, and a blouch dom 1.
car must be a blast to drive!!!
rexworx is online now   Reply With Quote
Old 02-26-2009, 05:32 PM   #20
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
When do I get my ride huff? Come to my house and pick me up. haha
D Money is offline   Reply With Quote
Old 02-26-2009, 05:46 PM   #21
jays05
Member#: 78165
05 STI 35r + e85
Looks great. I suggest you upgrade your IC core (to a garrett monstrosity) and uppipe (2.5" ID). Easy 30whp+ IMO.
jays05 is offline   Reply With Quote
Old 02-26-2009, 06:04 PM   #22
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
I'll def look into the IC core. The up-pipe will be bigger when I redo the turbo system.
Old 02-26-2009, 06:25 PM   #23
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
I can tell you now that the perrin header is killing the top end not the turbine housing ---check out the post on the slowmotion header vs. the perrin.I personally run the 2 1/2 outlet .82 housing with special kelford avcs cams and my trq on pure pump stays above 450 from 4800 past 7000 on 23.5 psi boost.
john 1badSTI is offline   Reply With Quote
Old 02-26-2009, 06:44 PM   #24
SiLLySTI
Member#: 155221
2007 STI
12.3@112 VF43 93oct
Nice power for 22psi. This thing must move nicely.
Please post some pics and vidz.
SiLLySTI is offline   Reply With Quote
Old 02-26-2009, 08:54 PM   #25
OppositeLock
Member#: 54060
205 + td04=12.4@109
V8 207+VF37=12.3@111
Very nice numbers and setup, can't wait to see what it does after the upgrades with the wick turned up! What are the chances of seeing this beast make some passes at Atco this Saturday?
OppositeLock is offline   Reply With Quote
Brand new GT35r, Clutchmasters, Raw Performance and More!!! Nolain Engine/Power/Exhaust 2 04-01-2010 12:02 PM
FS: Raw Performance Signature Series short block dubya-R-ex Engine/Power/Exhaust 5 11-30-2009 09:45 PM
FS: (CO) 04 STi RAW Performance Signature series heads Scuba Steve Engine/Power/Exhaust 13 02-17-2009 04:00 PM
FS: (CO) 04 STi RAW Performance Signature series cylinder heads Scuba Steve RMIC Private Classifieds 6 02-12-2009 10:01 PM
What is required to reach 500 whp on pump+meth with a gt35r? scutzi128 Built Motor Discussion 32 04-27-2008 04:14 AM
Message Board Statistics All times are GMT -4. The time now is 11:09 AM.
