#1 |
Member#: 119995
W. Canada
Vehicle:2004 Outback XT Peachy |
Hey Guys,
I wasn't able to get a 1819 radiator from anybody in the city in the next couple weeks but there was one 1183 radiator available (93+ impreza, 90-94 NA legacy). On that radiator, there is a place to install a nipple like the turbo rads have, just above where the top radiator hose goes. Would that work or should I wait the 2 weeks (and pay the extra $80) to wait for an 1819? Would my RS fans bolt up to this radiator? This is going in a 99 Impreza RS with a 2007 STI swap. Thanks in advance.
#2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Wait. That NA radiator doesn't have enough volume. I know some guys use NA radiators on their swaps but I've never thought it a good idea. You want the thicker core and better cooling of the turbo radiator.
#3 |
Member#: 119995
W. Canada
This core is the exact same thickness as the turbo radiator, the dimensions were identical with a slight difference in end tanks. These are aftermarket radiators, not OEM ones.
Edit: It's an aluminum rad with plastic end tanks. Last edited by silentt; 02-27-2009 at 01:53 AM. |
#4 |
Member#: 832
RMIC
Then I would compare the core thickness to the factory radiator. I realized that you weren't talking about OEM parts but not knowing the part numbers or brand you referred to, I just assumed that like every other one I've ever seen the turbo offering from these guys would be thicker.
#5 |
Member#: 119995
W. Canada
I just called the shop I bought the rad from and the owner said that both radiators are 25mm thick (+/- 2mm OEM spec), aluminum single row radiators.
This is the radiator I have (1183): ![]() This is the 1819: ![]() What I was wondering was if I could take the plug out of the top right of the 1183 and put in a nipple to connect to the coolant reservoir on the intake manifold which would function much like that of a radiator from a WRX/STI. |
#6 |
Member#: 832
RMIC
I think that's a bleeder valve. I think once you open that up you won't have an air tight closed system.
Do what I-Speed does. Tear the gasket out of the radiator caps and route the overflow pipe to the turbo tank. Then run the line off the turbo tank to the overflow. |
#7 |
Member#: 135730
NWIC
Vehicle:93 L |
Have you mearsured the 1183 core or are you taking the shop owners word for it. According to the following links the thickness varies between the two models. I am also looking for radiator solution while retaining my a/c condensor.
http://www.go-part.com/9094-subaru-l...3-p-24333.html http://www.go-part.com/9094-subaru-l...9-p-23203.html |
#8 | |||||
Member#: 119995
W. Canada
| Thread Tools | |
| Display Modes | |
| FS CA: Rad cap, turbo shield, gaskets | ralliharri | Engine/Power/Exhaust | 6 | 09-20-2008 08:30 PM |
| Replacement Studs for Turbo, Uppipe, Downpipe etc on McMaster? | disque71 | Newbies & FAQs | 12 | 11-02-2006 05:58 PM |
| vf28, Looking for turbo parts or used turbo | rallynutdon | Private 'Wanted' Classifieds | 5 | 05-06-2005 01:42 AM |
| Any benefit to replacing rad. hoses on STi? | mindchatter | Factory 2.5L Turbo Powertrain | 4 | 11-20-2003 01:41 AM |
| Looking for turbo kit using the GT25 turbo | dcoty | Normally Aspirated with bolt-on Forced Induction Powertrain | 16 | 10-18-2001 11:57 AM |
