Old 02-27-2009, 04:34 AM   #1
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
Default Stealth Monster
My 2007 Legacy Spec B that I've been slowy modding since I bought it new in March 2007.
Engine Specifications:
  • EJ255 390 WHP 387 WTQ on 92 Octane
Engine:
  • Group N Engine Mounts
  • Unorthodox Racing Light Weight Crank Pully
  • Unorthodox Racing Light Weight Power Steering Pully
  • Gates Micro V Belts
  • Denso Iridium Plugs
  • Zero Sports 71C Thermostat
  • Zero Sports Radiator Shroud
  • HPS Performance Silicone Coolant Hoses
  • Perrin Radiator Hoses
  • Perrin Dual Oil Catch Cans
  • Subtle Solutions Alternator Cover
  • SPT Billet Oil Cap
  • SPT Battery Tie Down
  • Optima Red Top Battery
  • Hella Supertones Painted DGM
  • RPA Hood Dampers
  • Koyo Aluminum Radiator
  • Perrin Radiator Mounts
  • Sti Coolant Expansion Tank
  • STI Radiator Cap
  • Kartboy Pitch Stop Mount
  • Killer B Optimal Oil Pan
  • Killer B Oil Baffle and Windage Tray
  • Killer B Ultimate Oil Pick Up
  • Reservoir Caps Vinyl Wrapped CF
  • Fuse Box Cover Vinyl Wrapped CF
  • Alternator Cover Vinyl Wrapped CF
  • + Battery Terminal Cover Vinyl Wrapped CF
Turbocharger & Induction:
  • Blouch 20G XT (7cm Hotside)
  • Prosport Turbo Heat Shield Blanket
  • AWD Tuning Turbo Heat Shield
  • Tial MVS 38mm VTA EWG (.9 Bar)
  • STI Intake Manifold
  • JDM TGV Deletes Ported and Polished
  • GrimmSpeed 8mm Phenolic Spacers
  • Perrin FMIC
  • Turbo XS RFL VTA BOV
  • Perrin Inlet Hose
  • Apexi Shortram Intake
Fuel & Tuning:
  • Walbro 255lph Fuel Pump
  • Fuel Injector Clinic 900cc Top Feed Injectors
  • Aeromotive Top Feed Fuel Rails
  • Custom SS Braided Fuel Lines & Fittings
  • Aeromotive A1000-6 Injected Bypass Regulator
  • Cobb Access Port 2.0 Tuned by Mike at PIA
Exhaust:
  • Tomei Expreme Unequal Length Headers Wrapped and Coated
  • IAG Performance Custom EWG Up Pipe Wrapped and Coated
  • CNT Performance Catless Downpipe
  • Perrin 3" Mid Pipe
  • Perrin 3" Y Pipe
  • Perrin Sport Tone Mufflers
  • Rallitek Polyurethane Exhaust Hangers
Drivetrain:
  • Exedy Twin Plate Clutch Kit
  • AP Braided SS Clutch Line
  • Motul RBF 600 Dot 4 Clutch Fluid
  • Group N 6 Speed Transmission Mount
  • Cobb 6 Speed Short Throw Shifter
  • Cobb Hardened Shifter Bushings
  • Cobb Hardened Rear Shifter Bushing
  • Whiteline Transmission Mount Bushings
  • Eneos 75w/90 Full Synthetic Transmission Fluid
  • Eneos 75w/90 Full Synthetic Differential Fluid
Brakes:
  • GrimmSpeed Master Cylinder Brace
  • DGM Brembo 4pot Calipers Front
  • DBA 4000 Slotted Rotors Front
  • Hawk HPS Pads Front
  • DGM Brembo 2pot Calipers Rear
  • DBA 4000 Slotted Rotors Rear
  • Hawk HPS Pads Rear
  • Techna Fit 6 Piece Custom SS Brake Line Set
  • Motul RBF 600 Dot 4 Racing Brake Fluid
Suspension, wheels & tires:
  • Sti Front Strut Bar
  • Cusco Rear Strut Bar
  • Jspeed Inner Front Fender Braces
  • Perrin 25mm Front Stabilizer Bar
  • Kartboy Front Endlinks
  • Perrin 25mm Rear Stabilizer Bar
  • Kartboy Rear Endlinks
  • Perrin Rear Stout Mounts
  • Emotion Fukuoka Rear Stabilizer Support Brackets
  • Cusco Front Cross Member Power Brace
  • Cusco Front Lower Arm Bar Type II
  • Cusco Rear Lower Arm Bar Type II
  • Cusco Rear Side Power Braces
  • Cusco Rear Lower Power Brace
  • AVO LCA Front Control Arm Bushings
  • AVO Caster Bushing System [+0.50 caster]
  • AVO Steering Shaft Bushings
  • Whiteline Front Roll Center/Bump Steer Correction Kit
  • Whiteline Adjustable Rear Control Arm Kit
  • Whiteline Rear Toe Lock Bolt Kit
  • Whiteline Front Diff Bushing Kit KDT905
  • Whiteline Rear Diff Bushing Kit KDT906
  • BC Racing BR Series Coilovers
  • 18x8 +48 O.Z. Racing Alleggerita HLT's
  • BF Goodrich 235/35ZR18 g-Force T/A KDW NT's
Interior:
  • Greddy Turbo Timer
  • Greddy Boost Controller
  • Defi Link System
  • Defi Amber Red Boost Gauge
  • Defi Amber Red Water Temp Gauge
  • Defi Amber Red Oil Temp Gauge
  • Defi Amber Red Oil Pressure Gauge
  • Defi Amber Red Exhaust Temp Gauge
  • JCS Pods Dual A-Pillar Gauge Pod
  • Rally Innovations Quic-Trac Harness Bar
  • Corbeau 3 Inch 5-Point Harness x2
  • Shifter Bezel Vinyl Wrapped Flat Black
  • Both Stereo Side Trim Pieces Vinyl Wrapped CF
  • Dual HVAC Double Din Kit
  • Pioneer AVIC-Z120BT Head Unit
  • Polk Audio DXi6500 6-1/2" Front Components
  • Polk Audio DXi6500 6-1/2" Rear Components
  • JL Audio 10W3v3-4 Subwoofer
  • Kenwood XR-5S 5 Channel Amp
  • Tsunami Litewave 1.2 Farad Capacitor
Exterior:
  • Central Composites Carbon Fiber Lip
  • R-Rev Carbon Fiber Grill
  • R-Rev Eyelids Painted DGM
  • R-Rev Carbon Fiber Fog Light Bezels
  • R-Rev Carbon Fiber Rear S Type Spoiler
  • Stanza Carbon Fiber Rear Window Spoiler
  • K2 Carbon Fiber Grill Emblem
  • K2 Carbon Fiber Trunk Emblem
  • Windshield Panel Vinyl Wrapped CF
  • Side Window Trim Vinyl Wrapped CF
  • B-Pillar Trim Vinyl Wrapped CF
  • Side Skirt Trim Vinyl Wrapped CF
  • OEM Mud Guards Vinyl Wrapped CF
  • Rear Diffuser Vinyl Wrapped CF
  • Carbon Fiber License Plate Frame
  • Cleared and Blacked Out Headlights
  • DRL Delete
  • Windows Tinted to Legal Limit
  • DeBadged All Except Suby Emblems
  • Gorilla Aluminum Tuner Lug Nuts Black Anodized
  • Side Mirror Turn Signals Vinyl Wrapped Smoke
  • Tail Lights Vinyl Wrapped Smoke
  • Rolled Fenders Front and Rear
Some pictures taken through out the build:
http://legacygt.com/forums/showthrea...-b-117513.html
http://legacygt.com/forums/album.php?albumid=51
Armin Ausejo Photoshoot September 2010:
http://verdugo.smugmug.com/Cars/Chris-Legacy-GT-Spec-B
SubyStud555 is offline   Reply With Quote
Old 02-27-2009, 06:33 AM   #2
07STi305
Member#: 202720
2007 STi
Gray
I love The Legacy . I always wanted to buy one! once i get a little bit older!! car looks good !! Good Job.
07STi305 is offline   Reply With Quote
Old 02-27-2009, 07:15 AM   #3
Jim.mEh
Member#: 84517
05' Imprezilia
CruiseControl Warrior
Exclamation
Jim.mEh is offline   Reply With Quote
Old 02-27-2009, 07:27 AM   #4
sti robot
Member#: 110932
2013 BRZ
I like everything but the gauge setup. It's too much and too temporary looking. Look into a magden or a hks camp or something like that.
sti robot is online now   Reply With Quote
Old 02-27-2009, 07:36 AM   #5
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
i love it! looks great! ....i like how from the outside you have no idea what's lurking under the hood. nice sleeper.
boostdog is offline   Reply With Quote
Old 02-27-2009, 07:55 AM   #6
Boosted Up
Member#: 154828
04 & 12 WRX 06 STI
It's like the perfect woman.
Lady on the street, freak in the sheets.
Boosted Up is offline   Reply With Quote
Old 02-27-2009, 07:58 AM   #7
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
very nice sleeper bro, i like it!
xrocket21 is offline   Reply With Quote
Old 02-27-2009, 08:55 AM   #8
98Legacy_757
Member#: 183874
95 Integra SE
w/ 01 ITR exterior!?
doode that looks like your in a plane with all those guages haha i like, LGT ftw
98Legacy_757 is offline   Reply With Quote
Old 02-27-2009, 08:59 AM   #9
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
This Spec-B is a sleeper. The only thing I would change it the BOV. (Im thinking Tial)
cpunlamd is offline   Reply With Quote
Old 02-27-2009, 09:07 AM   #10
generic_punk_kid
Member#: 199666
1990 300zx 2+2 TT
Soon to be black
synapse synchonic bov ftw
generic_punk_kid is offline   Reply With Quote
Old 02-27-2009, 10:48 AM   #11
pdx Nick 05 LGT
Member#: 179490
2005 Volvo S40 T5
Flint Gray
did you notice much difference after switching to group n mounts?
pdx Nick 05 LGT is offline   Reply With Quote
Old 02-27-2009, 11:18 AM   #12
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
sweet legacy
shadowmd is offline   Reply With Quote
Old 02-27-2009, 11:20 AM   #13
bigb402
Member#: 137974
2000 Impreza 2.5rs
STM
nice work bro!
bigb402 is offline   Reply With Quote
Old 02-27-2009, 11:29 AM   #14
0wrx2
Member#: 82297
awesome leggy. engine bay is impressive!
it needs some kind of a front lip though. the fronts on those look like a wedge.
0wrx2 is offline   Reply With Quote
Old 02-27-2009, 11:31 AM   #15
PhantomPilot
Member#: 202275
Chapter/Region: PRSIC
2003 Impreza WRX
Sedona Red
Nice "Q ship."
PhantomPilot is offline   Reply With Quote
Old 02-27-2009, 11:38 AM   #16
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Your car looks familer. was it at the sushi meet thing in WA last weekend?
thats a lot of gauges. looks good.
Mavrik is offline   Reply With Quote
Old 02-27-2009, 03:03 PM   #17
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
Yeah there is a noticable difference, a lot less engine movement and smoother accelaration. I would highly recommend these if you not running stock.
Old 02-27-2009, 03:04 PM   #18
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
Yes it was, were you there?
Old 02-27-2009, 03:05 PM   #19
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
Thanks for all the comments everyone!
Old 02-27-2009, 03:05 PM   #20
Calitri-Boost
Member#: 109090
08 IS-F
WFC Mbr # 004
looks good
Calitri-Boost is offline   Reply With Quote
Old 02-27-2009, 03:09 PM   #21
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
I agree. The gauges don't do anything for me.
But VERY nice Spec B!
96accord is offline   Reply With Quote
Old 02-27-2009, 03:14 PM   #22
NOboostSUBIE
Member#: 163322
2002 PSM Impreza RS
DD & Weekend Auto-x'r
loving the spec B....the gauges are a bit overkill, but hey If you need them, you need them. Maybe just the placement is what is throwing me off.
NOboostSUBIE is offline   Reply With Quote
Old 02-27-2009, 03:23 PM   #23
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
i couldnt agree more. that POS has to go!
i know the lgt platform lacks gauge pod options, but that is just crazy. +1 for awesome gauges, -1 for placement. haha so they basically cancel each other out
all in all your specb is badass though! keep up the good work!
wrxtremeWGN is online now   Reply With Quote
Old 02-27-2009, 03:36 PM   #24
generic_punk_kid
Member#: 199666
1990 300zx 2+2 TT
Soon to be black
you could run the gauges and have a telemtry readout like the gtr's but thats way to expensive
but i dont mind the gauges, because everything in your car is amber red, so badass
Old 02-27-2009, 03:38 PM   #25
Ntercooled
Member#: 120100
2004 WRX stage 2
Soon to be vf43'd
Looks great! its really clean
Ntercooled is offline   Reply With Quote
Rocket Rally Racing Modded 07 Legacy spec.B HarryZ Vancouver Impreza Club Forum -- VIC 38 10-27-2009 05:25 PM
Pics and Mod List Matth3w Member's Car Gallery 54 12-06-2007 09:04 AM
Ebay Exhaust (X02 Racing) and Cobb DP on an 07 Legacy Spec.B coldeagle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-07-2007 02:18 AM
Singapore Spec Legacy 2.0i pics and review kmin Legacy Forum 10 01-23-2004 02:05 AM
Sunny Day = Updates Pics and Mods List topcover Member's Car Gallery 7 02-25-2002 05:20 PM
