Old 02-27-2009, 07:27 PM   #1
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Default Putting car on the dyno tomorrow, where to strap to?
Not sure where to ask this, but I figured this would be the best place.
I will be putting my car on the dyno tomorrow, and I am not sure how many Subarus they have strapped down. If I was dealing with a little more than stock power I wouldn't be as concerned, but I am hoping to hit 500+. The other issue is that I also removed the front u-brace and the right rear tow hook.
Where do they normally run the straps to? Where should I have them strap to? Control arms? Lateral links? Any other ideas?
Thanks in advance, and the sooner I can figure this out, the better.
Rizzo314 is offline   Reply With Quote
Old 02-27-2009, 07:39 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Suspension arms.
That is where I've had my car strapped down several times and had no problems.
More than likely the people running the dyno will know how to strap down your car. If they don't, I wouldn't trust them to drive my car onto the dyno in the first place.
speedyHAM is offline   Reply With Quote
Old 02-27-2009, 07:43 PM   #3
Rizzo314
Member#: 42215
Originally Posted by speedyHAM View Post
Suspension arms.
Ok, thanks. I'm sure they can handle that. I didn't know if I had removed the common strapping points (u-brace and tow hook).
I also didn't want to dig the u-brace out and bolt it back on if I didn't need to.
Old 02-27-2009, 08:48 PM   #4
Super Nintendo
Member#: 73721
2007 STI
PTE 6266
Do you have WRX lateral links still? Those have a tendency to bend.
Super Nintendo is offline   Reply With Quote
Old 02-27-2009, 10:27 PM   #5
Rizzo314
Member#: 42215
Yes, I do.
Old 02-27-2009, 10:47 PM   #6
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
best bet is to call or pm some other dyno shops that tune lots of subies. or maybe they will chime in?
woodys77 is offline   Reply With Quote
Old 02-27-2009, 10:59 PM   #7
Epic Motorsports
Member#: 198925
If you have the factory front subframe there is a tow hook loop on both sides in the front look under there you will see them. and I cross the fronts.
On the back straps look near the exhaust there is a small loop latch into there. and next to the carbon canister on the passenger side rear. I leave thm straight so the exhaust doesnt burn them.
Epic Motorsports is offline   Reply With Quote
Old 02-27-2009, 11:10 PM   #8
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
^^^good pointers
pretty cool you have your vendor's sn now
blowbyu24 is offline   Reply With Quote
Old 02-27-2009, 11:16 PM   #9
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Thanks Cole. Hopefully you are able to make it down this summer nice chatting with you the other day.
robbieshonda is offline   Reply With Quote
Old 02-27-2009, 11:35 PM   #10
boostin23
Member#: 204172
---- 05 STi
Suspension arms.
yea thats true
boostin23 is offline   Reply With Quote
Old 02-28-2009, 07:47 AM   #11
Rizzo314
Member#: 42215
I have neither the front sub-frame or the right rear tow hook. That was my original reason for asking my question.
Old 02-28-2009, 09:05 AM   #12
Epic Motorsports
Member#: 198925
Ahh yeah didnt read that.
Then the front control arms and the rear lateral links work well. If they have axle straps.
Old 02-28-2009, 12:29 PM   #13
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
IMO if you are really building a +500whp car then using a wrench shouldnt be a real big problem. IMO Id reinstall the front subframe and the rear tow hook.
even on the dyno a 500whp car puts out some forces.
If they tried using the lateral links and control arms id never let them touch my car.
Stamped steel front control arms bed, steel lateral links bend as well. if you have a sti or have upgraded to aluminum control arms or lateral links then your front and rear subframe gets tweaked where they attach to the subframes
rexworx is offline   Reply With Quote
put my car on the dyno azn2nr Rocky Mountains Impreza Club Forum -- RMIC 12 10-09-2009 04:44 AM
You wanted to see my car on the dyno? moosecakes North West Impreza Club Forum -- NWIC 22 07-22-2009 04:08 AM
PHINNALLY!!! going on the Dyno tomorrow THE-95-STi Mid Atlantic Impreza Club -- MAIC 31 11-14-2008 10:00 AM
Got the car on the dyno @all aspects boost4life Mid Atlantic Impreza Club -- MAIC 16 07-11-2006 07:26 PM
what #'s does a stock evo 8 put out on the dyno? SiC Stoner Off-Topic 38 01-26-2006 09:23 PM
