Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-27-2009, 09:08 PM   #1
nation1979
Member#: 192914
06 sti
importimageracing is #1
Default how to properly attach copper ends to amp wire
i was wondering what method you guys use when attaching copper rings to 4ga power/ground wires for amp kits.i buy in bulk and plan on making my own grounding kit for a quater of the price people charge.
nation1979 is offline   Reply With Quote
Old 02-27-2009, 09:16 PM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
Ratchet crimper, vice and a nail. Just because I can't affford a hydraulic crimper
Daishi00 is offline   Reply With Quote
Old 02-27-2009, 09:23 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Hammer-crimpers FTW
Audiosavvy is offline   Reply With Quote
Old 02-27-2009, 09:24 PM   #4
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
how does the nail come into play?
i have always just used a larger hand crimper (handles were around 14 inches i think?) for larger ring terminals, along with solder
The Satch is offline   Reply With Quote
Old 02-27-2009, 09:27 PM   #5
Daishi00
Member#: 78952
2005 WRX
CGM
Use the nail to push one portion of the terminal in and then fold the other over. Then hit it with the big ass ratchet crimpers I have. Unfortunately there still isn't enough pressure to cold weld the two together, which is what you actually want to achieve.
Old 02-27-2009, 10:16 PM   #6
Uncanny
Member#: 133012
2015 STi
Lightning Red
bench vise and a long screw ftw
a little soldier if you're paranoid
Uncanny is offline   Reply With Quote
Old 02-28-2009, 12:45 AM   #7
nation1979
Member#: 192914
06 sti
iknow im asking alot but do you have a pic of the tools?i want to buy the right ones.i figure what i save doing it myself will payoff
Old 02-28-2009, 09:55 AM   #8
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
something like these channellock crimper/cutter will do the trick for most connections.
It isn't ideal for anything larger than 8 gauge though. To do a 4 gauge crimp you would have to probably do 3-4 separate crimps to get it right. Either way it is a pretty cheap tool and is worth it to add to your tool box.
A cheap solution for larger gauge wires is a hammer crimp tool.
Just to give you an idea of what to look for.
thedaddyb is offline   Reply With Quote
Old 02-28-2009, 01:20 PM   #9
nation1979
Member#: 192914
06 sti
thanks.im heading to sears to pick up both.i have about 40' of 12,10 &8 GA and about 20' of 4 ga.yesterday i picked up all the connectors and there was a guy selling a whole lot of stereo stuff(10 inline fuse holders,mounts,5 caps and 3 battery blocks)got all that for 25$
Old 02-28-2009, 01:46 PM   #10
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Dude, a hammer and a concrete floor is all you really need..
IF you DO decide to solder, a simple propane torch will do what you need, just torch the very tip of the terminal, and allow the heat to move down into the wire.. apply the solder and then cool it as quickly as you can... a moist towel will help with that, without "dunking" it...
Old 02-28-2009, 04:54 PM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I don't really agree with that. Sure it can get it done, but you're going to have a fat, flat crimp, not something properly wrapped over itself and in a nice tight, clean package. The hammer-crimper set is what I use for anything over 8ga. I put it in, upside down at an angle, give it a half-tap to start the overlap, then straighten it and give it 2 solid wacks. I have never EVER had a problem
Old 02-28-2009, 05:45 PM   #12
nation1979
Member#: 192914
06 sti
i cant seem to fid the hammer kind.ebay may be a option
the hand crimper shown said it was only good upto 10 gauge.im making a bunch of 8 gauge grounds and 4 gauge power lines.i should be able to make 10 complete kits for 30 shipped.tha will be after i master the crimper though.i dont half ass stuff like that
How do I attach trunk badge to front grille? Aben92 Interior & Exterior Modification 13 11-20-2009 02:41 AM
How to properly wire a radiator fan with a switch? Kwyjibo Electrical & Lighting 0 08-26-2005 07:16 PM
Amp wiring questions - how to, multiple speakers? mhaythor Car Audio, Video & Security 4 06-07-2005 07:47 AM
60 amp inline fuse for amp wiring kit blew, where to buy replacement? garie Car Audio, Video & Security 11 03-14-2005 11:17 PM
How to proper wire external pumps DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-17-2002 07:14 AM
