Old 02-27-2009, 09:25 PM   #1
family wRXagon
Member#: 188380
2002 WRX wagon
273 awhp
Default check engine light comes on and i have utec
So just the the other day my wife noticed when i turned the car on the CEL was on. it never turns on when i start the car. It only turned on when i had the key turned to ACC to run the radio or what ever. But know when i start the car it stays on and turns off with the ABS light. Should i worry or leave it be? The car runs fine, although i have a slippy clutch thats getting fixed tuesday. The clutch should have nothing to do with the CEL right? Could the problem be that i need an oil change? i'm alittle over due.
family wRXagon is offline   Reply With Quote
Old 02-27-2009, 11:05 PM   #2
EsubaruJ
Member#: 200008
85 AE86
01XJcrawler02WRXsold
If it doesn't stay on you shouldn't have to worry. If it starts flashing thats when you worry lol.
EsubaruJ is offline   Reply With Quote
Old 02-27-2009, 11:42 PM   #3
Bug-Rex
Member#: 190935
02 Slam'd Bugeye
LOL member accnt. points
That is supposed to happen. It does that in like every car when you just use the electronics.
Bug-Rex is offline   Reply With Quote
Old 02-28-2009, 01:38 AM   #4
family wRXagon
Member#: 188380
2002 WRX wagon
273 awhp
Ya so it turns off with the airbag light not the abs as said before. But drove it tonight and no CEL as normal. Don't know why I was seeing one at all during start up. Oh well will report back if it comes back.
check engine light comes on at low gas halftendril Normally Aspirated Powertrain 2 11-28-2002 11:05 AM
check engine light comes on at low gas? halftendril General Community 1 11-28-2002 02:49 AM
replaced the T and the hose and the restrictor now the check engine light comes on scoobydoo02 Factory 2.0L Turbo Powertrain 2 05-04-2002 10:21 PM
Need help- check engine light coming on, think I am pushing around 20 psi scoobydoo02 Factory 2.0L Turbo Powertrain 7 05-04-2002 09:01 PM
Check engine light coming on and off, seemingly randomly GusS Legacy Forum 8 12-07-2001 01:50 PM
Message Board Statistics All times are GMT -4. The time now is 06:37 PM.
