Old 02-28-2009, 05:38 PM   #1
MasterKwan
Member#: 98961
2003 WRX
Default 03 WRX to 05 STI Steering columns
I started with a wrecked 05 STI, swapped everything over (EVERYTHING) and am working on the steering columns since the STI airbag was blown.
1) Cost of a clockspring is $184-255 depending on where you get it.
2) Cruise control and horn setup is completely different.
3) You can't take the guts of the 03 steering column and install them on the 05 column. Subaru has actually changed (for no reason) the width of the mounting bracket so, the 05 and 03 blinker/wiper control unit won't swap over (well, not without drilling).
So,
1) assuming the STI clockspring is still OK (blowing the bag sometimes damages them), I can solder a new connector onto the airbag harness and use my WRX wheel and remove the Cruise control harness, splice in and and make the horn work.
2) I can re-drill the bracket and install the guts of the 03 column onto the 05 column.
Either way the immobilizer parts from the 05 column will continue to function. My goals are, airbag and horn working. Once I find an STI wheel, I can just swap it over and everything will work.
Old 03-01-2009, 11:33 AM   #2
MasterKwan
Member#: 98961
2003 WRX
To answer my own questions, I'm swapping the guts over and welding some washers into the bracket to allow the wrx blinker/headlight parts work on the sti column.
FS: 03 wrx swap 05 sti engine and 6 speed tranny (Glen Ellyn) (IL) AlexTseng Private Vehicle 'For Sale' Classifieds 71 10-13-2009 06:41 PM
03 Bugeye to 05 STi rear end...will it bolt up? dlh1999 Interior & Exterior Modification 18 06-30-2009 11:33 PM
03 wrx to 05+ sti center console swap, what's needed? D Money Interior & Exterior Modification 39 10-08-2008 11:35 PM
Request, 03 wrx with 05 STi wheels and brakes. 03twrx Member's Car Gallery 11 02-23-2005 01:02 AM
WA-WTB: WRB sideskirts 02-03 WRX/04-05 STi HiFiWRX Private 'Wanted' Classifieds 14 11-09-2004 11:07 PM
