Old 03-21-2010, 09:55 PM   #1
SharpByCoop
Member#: 199906
2008 Infiniti G37S
World's quickest: 11.13"
Default 11.21 @ 124 '06 STI The Shop/Jr Pump Gas Full Weight
Car: 2006 STI – 2.5L
Tuner/Shop: Junior2JZ / The Shop, Norwalk, CT
Dyno Info: Dyno Dynamics (1.2 CF)
Peak HP at RPM: 494hp @ 7000rpm
Place: Island Dragway, NJ
Date/Conditions: 03/21/10, 60 w/slight headwind.
Fuel: 93oct Sunoco unleaded pump
Engine block: Headway Performance cast iron sleeved, O-ring & balanced
Pistons: Wiseco HD
Rods: Manley Turbo-Tuff
Oil pump: Cosworth
Engine bolts/Studs: ARP
Cyl heads: OEM Valves & ports. Decked surfaces
Cams: Kelford 272 w/valve springs
Intake manifold: 2007 w/ TGV deletes
Injectors: 1000cc w/Perrin fuel rails
Turbo: Rotated HTA3582 (GT35R) w/.82 exhaust housing, HTA: Aluminum compressor rotor
Exhaust: Perrin EL header & Greddy 3” catback
Tial EWG – internal reroute
Synchronic BOV – internal reroute
AMR FMIC w/intake plumbing
AEM Standalone EMS Computer
Catch cans: Oil/Crawford, Coolant/AMR
Reverse Hood sCoop vents :^)
Clutch/Flywheel: Clutchmaster Stage IV / Aluminum
Tires: Hoosier 245/45x17
Trans: 2007 STI 6-spd trans (longer ratios)
Take a back seat ride with me:
This was my final pass, because I had to leave early. Conditions were near ideal.
The track, unlike last year’s Spring was not crowded and started two hours earlier. You could have gotten in 20 passes, no kidding.
I had four earlier 11-second passes, but each of them had a mis-shift or delay shifting problem. This has been my biggest hurdle, working the finicky gates on the Subaru. It’s me, I know, and I’m getting there.
You can see that an even cleaner launch (I had a 1.57 60” earlier), and much quicker shifting is probably worth the two tenths I needed to get a ten second time card. Junior looked at my vid and thinks I may have a broken motor mount because of the movement. We will put it on the lift this week to inspect. (That would certainly account for poor shifts, but we’ll let the jury decide that later.)
Regardless that I did NOT get a ten second pass, it’s still my personal best, and it’s still a blisteringly fast car, especially on pump!
I’m going to return next month. News as I do.
Coop
SharpByCoop is offline   Reply With Quote
Old 03-21-2010, 10:26 PM   #2
Copper Rex
Member#: 53721
35R Bugeye
[email protected]
wow my slip looks almost identical to yours except for the trap speed. u trapped 4mph faster. Its amazing the difference 07 gears make compared to the shytty 04 gearing in mine. cant wait for that mod, its def worth it. congrats on a great run tho, i could see 10's on pump for sure. are u running the id1000cc injectors???
Copper Rex is offline   Reply With Quote
Old 03-21-2010, 10:37 PM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
nice job!
I see 10s on pump in your future.
Breathe and relax at the track and you will never miss a shift again
Old 03-21-2010, 10:40 PM   #4
bgod
Member#: 100274
Awesome!
Another fast pump gas car in the tri-state.
10's are right around the corner for you.
bgod is offline   Reply With Quote
Old 03-21-2010, 10:46 PM   #5
pezcore
Member#: 178045
06 WRX
CGM
Nice, I need a newer 6MT. I'd be in 6th gear before the 1/4 mark
pezcore is offline   Reply With Quote
Old 03-21-2010, 10:49 PM   #6
richy_21
Member#: 58670
2005 got muuuuu?
Originally Posted by juanmedina View Post
nice job!
^this. You sure smacked 2nd
richy_21 is offline   Reply With Quote
Old 03-21-2010, 10:53 PM   #7
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
the 07 gearing does make it easier but it can be done on the 04-05 gearing,it just takes practice and lightning quick solid shifts.
john 1badSTI is offline   Reply With Quote
Old 03-21-2010, 10:54 PM   #8
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
You did it my friend !!!
Kakaletris power bro! Kakaletris mf power!
No one can touch THESHOPCT.
BUILTSTI is offline   Reply With Quote
Old 03-21-2010, 11:07 PM   #9
kouzman
Member#: 228093
Congrats man! excellent job!
I see that every time you go to the track there is only improvement!
How did you like the Hoosier tires? You are running the 245/45-17 right?
kouzman is offline   Reply With Quote
Old 03-21-2010, 11:25 PM   #10
02h20
Member#: 130079
2006 STI [email protected]
[email protected]
Nice run. How did you like the tires?? Fast subarus coming out this year. Congrats
Copper Rex when you hitting the track again??
02h20 is offline   Reply With Quote
Old 03-21-2010, 11:38 PM   #11
syoung0298
Member#: 84772
2005 GDB STI
awesome run.. how much boost; what were your AFR's and peak timing at redline..
thanks..
syoung0298 is offline   Reply With Quote
Old 03-21-2010, 11:39 PM   #12
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
nice job man
06-wrx-tr is offline   Reply With Quote
Old 03-22-2010, 12:10 AM   #13
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
goodjob coop! 10s are around the corner!
~Stu
OVeRBOOSTn is offline   Reply With Quote
Old 03-22-2010, 12:10 AM   #14
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
~Stu
Old 03-22-2010, 08:57 AM   #15
SharpByCoop
Member#: 199906
2008 Infiniti G37S
Thanks, guys. I appreciate the props. Anyone who's been out there knows it's rare to get the glory card easily.
Yes, these Hoosiers are a great tire. Junior tells me he would have upped the launch 2-step RPM and raised tire pressure.
Timing, AFR's, Boost? Damned if I am certain. We had it on the dyno earlier in the week and it made this power at 25 lbs, and it was under 11.5 AFR all the way across. That was there.
I hear a track rental is in the cards for April. Yes, that would be fine.
Coop
Old 03-22-2010, 09:50 AM   #16
AMR
NASIOC Manufacturer
Member#: 171509
Coop,
Looks good. Congratulations on the 11.2 pass. You are getting closer to your goal.
-Rob & Albert
AMR is offline   Reply With Quote
Old 03-22-2010, 10:15 AM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I guess you need to trade down to an FP Red like john's??
So whats the difference between johns car and this car? With jays gt35 it was the trans why the mph was "down"......so this car has an even bigger turbo (HTA 3582) and an 07 trans.....and its still trapping the same as john's car?
Old 03-22-2010, 10:19 AM   #18
impreza914
Member#: 199499
2007 ford f150
subau coming soon
wooow great run ! i was the kid that helped you carry the tires to your car saturday while my friend was getting his wrx tuned..
impreza914 is offline   Reply With Quote
Old 03-22-2010, 10:19 AM   #19
jays05
Member#: 78165
05 STI 35r + e85
To me it looks like the biggest differences are that john's car had a 1.50 60' time and his LC/FFS rpm setpoints are probably higher. I improved 2-3mph and 2-3 tenths by playing with those RPM setpoints.
jays05 is offline   Reply With Quote
Old 03-22-2010, 10:27 AM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
still.....you dont think you guys should be killing that FP red?
i mean this fp red is the greatest arguement for staying stock location that i've ever seen.
Old 03-22-2010, 10:28 AM   #21
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Different cams different heads...
see below..
FFS is off on my car.
My launch control builds boost and was set higher on my 10.9 pass.
I believe Coops LC isn't building boost, or as much boost.
Remember I've had 3-4 more passes then Coop so far this year, before My 10.9 pass I was clicking off 11.2's.
When he finishes dialing in the car it'll go 10.7's
Old 03-22-2010, 11:29 AM   #22
Copper Rex
Member#: 53721
35R Bugeye
[email protected]
Hopefully soon, jus waiting on the dss axle that i snapped in half. BTW, nice job at the evo vs sti event reppin the subies. Unfortunately couldnt make it that weekend.
Old 03-22-2010, 11:32 AM   #23
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
2003 Corvette ZO6 400whp
Nice run... you'll get 10s!!!
btw... why a 2007 intake manifold?
DC5edSTI is offline   Reply With Quote
Old 03-22-2010, 11:46 AM   #24
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
very nice run man!
Did they not try to kick you out due to not having a cage installed? or did i miss that on the list of mods?
boostdog is offline   Reply With Quote
Old 03-22-2010, 12:20 PM   #25
alloutSTI
Member#: 241552
2015 GMC Sierra Z82
Subterranean Metallic
what RPM are you shifting at?
alloutSTI is offline   Reply With Quote
