#1 |
Member#: 137902
Vehicle:---- Last night I dreamt of San Pedro |
so i got this car. 4eat 166K with a delay between 2-3 gears. is that pretty normal and how good on average is this auto tranny good for?
#2 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
How good is the average good? In what specific area?
Check trans fluid condition and level as according to manual. Burnt fluid is dark and smells well...burnt believe it or not. Metal filament looking particles are a sure sign of wear too. Get a sample of clean dextron for color comparison. Use a white card or white cardboard piece (something opaque and white). Achieve operational temp through driving, shift through all positions and then to park. Let idle for a few ticks and turn off and check level. (or similar) Delay is not normal. Though the trans is easily temporarily "confused into irrational behavior" by multiple driving styles and rapid changes in throttle application whilst cruising in "D" especially. If its a genuine delay a 2-3 up shift at WOT will likely produce an encounter with the rev limiter. (whilst on dry pavement in 3 or higher since being in 2 locks the trans in 2 alone) This is not really recommended since your trans may very well be compromised in some way and also this up shift would occur at the mid 70's MPH. If the fluid is fine then have it prodded and test driven by someone who would know the difference. From a modability standpoint for the "suggestion box" trans itself... it is... to much higher (relative) accelerative result. CN: Just noticed your the guy with the 2.2 leggy turbo so some of that may or may not be WRX specific. (they dont sticky slushbox info round these parts...) Last edited by 02redwagone; 02-28-2009 at 10:14 PM. |
#3 |
Member#: 137902
thanks wag. manual would have been nice but the wife wanted me to get something she could drive if she had to.
#4 |
Member#: 95652
Vehicle:'12 Outback 2.5i '10 Legacy 2.5i ltd. |
edit: nvm
#5 |
Member#: 204381
Hi, Need help, had my engine rebuilt and replaced back in, but now when put in drive it wont change upto 2nd gear,just stays in 1st, wont even change up if i shift the stick into 2nd let alone 3rd ,its a 4eat trans
| Thread Tools | |
| Display Modes | |
| 4EAT slips or hesitates on 2-3 shift | gtbensley | Transmission (AT/MT) & Driveline | 2 | 11-04-2008 09:04 AM |
| Help! My shifter buzzes/vibrates on the 1-2 and 2-3 shifts | ButtDyno | Transmission (AT/MT) & Driveline | 9 | 05-06-2004 01:46 AM |
| Small whine in 1-2 and 2-3 shift when cold | jmaiken | Transmission (AT/MT) & Driveline | 3 | 10-28-2003 03:37 PM |
| keep missing my 2-3 shift, finding 5th instead of 3rd | annointed | Transmission (AT/MT) & Driveline | 16 | 05-13-2002 01:07 AM |
| TPS adjustment for 2-3 shift | glenstiles | SVX Forum Archive | 8 | 01-11-2001 08:50 AM |
