Old 02-28-2009, 10:36 PM   #1
96subie96
Member#: 186777
1996 GC 22t 87 justy
91 wagon2.2 99outback
Default 2.2t overheating
I put in a 2.2t out of a 93 ss leg into my 96 impreza brighton. I left the radiator from the 1.8 that was in it. Is it to small of a radiator? And no intercooler. I just bought one for it but I know they came stock without. Could it be that its in a super light car, I dont know. Any help would be nice. It just sitting in my garage because Im afraid to drive and screw something up.
96subie96 is offline   Reply With Quote
Old 03-01-2009, 02:16 PM   #2
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
mmm, i would suggest putting in a bigger radiator, i donno if the factory radiator from the leg would swap, but that would prob be your best bet. I know when i did my SR20DET swap in my nissan and used the factory 240sx radiator it would overheat in hot weather because it couldnt keep up.
start by taking it out on small runs and see how it does, just be careful.
Rei_Akira is offline   Reply With Quote
Old 03-05-2009, 03:25 PM   #3
Snowbum
Member#: 185913
2001 2.5rs
Grey
replace the thermostat.
Snowbum is offline   Reply With Quote
Old 03-05-2009, 04:07 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Pull the radiator and clean it with HVAC AC condenser cleaner ( acid ) it will look something like this and you can get it at commercial HVAC-Heating supply stores $7.99-$11.99 a gal mix 50/50 with water and spray it on both sides with hand sprayer or pump sprayer wait 20-30 minets and thuroghly hose clean....its the stuff they used to clean your outside home AC unit for boo-koo $$$
Dont bother with anything that is "indoor use" or "no rinse". It will not be strong enough to cut through the road and bug grime. I have used it on numerous radiators, it restores them to like new in no time with no scrubbing. I will say this dont use it unless you pull the radiator....its powerful stuff and will cause corrosion on your car body-frame if not washed away with water....like if your battery blew up
B4 you go and buy a new thermostat pull your old one and drill 3-4 3/16" holes in it around the edge and put it back in. That will let water flow with out the thermostat opening and help keep temps down....if it does the trick get a lower temp thermostat 170-ish
dangerousatom is offline   Reply With Quote
Old 03-16-2009, 10:24 AM   #5
leftho0k
Member#: 177589
I thought that engine sawp is illegal for road use in the usa and punishible by national law with up to a $10,000 fine per veh.? shouldnt you be keeping it on the d/l?
leftho0k is offline   Reply With Quote
Old 03-29-2009, 12:05 AM   #6
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
^ are u for real.
i hear all sorts of ****ed up things from that country down below.
hey, why dont we take away everyone's freedom and not let anyone have black cars and engine swaps.
black cars??? didnt you know they take more a/c to cool???
wtf is wrong, we should have a huge black car meet and riot
Joynt93 is offline   Reply With Quote
Old 03-30-2009, 04:29 PM   #7
dscoobydoo
Member#: 57152
---- Subaru fleet
garage ( 5 and counting)
The 2.2T engines have a very large capacity radiator. this is due to the fact that: they are turbo engines, and without the intercooler, it is a way to keep temps low.
I would try and retro fit the 2.2t radiator into the brighton. It should fit without any major modifications.
I would also consider adding ANY intercooler. That is one of the first mods for the SS crowd.
If your car does not have the hood scoop, then you can always go AWIC.
dscoobydoo is offline   Reply With Quote
Old 03-31-2009, 09:19 PM   #8
FuzzyFish
Member#: 106451
1984 Corolla SR-5
Red and Black
You'll need a larger radiator for sure. The one in my leggy turbo is quite bigger/thicker than the stock 1.8 one I'd highly doubt it could keep up with the demands.
FuzzyFish is offline   Reply With Quote
Old 03-31-2009, 09:24 PM   #9
darksc00by
Member#: 102140
Why is it illegal? That means if your motor goes, it's illegal to get another motor for it? Wouldn't it mean that junkyards selling motors would be illegal?
I don't see why it would be illegal at all. I have a swapped RS, my rs is obd2, so is my motor....
darksc00by is offline   Reply With Quote
Old 04-02-2009, 07:16 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I doubt the radiator is too small. How do I know?
I swapped an 05 STI engine into a 98RS and used the radiator from a 93 FWD automatic Impreza. It is the thinnest radiator I have seen and the capacity is slightly reduced because of the transmission cooler inside.
My first vote is that your fans aren't working properly. Second would be the headgasket.
Old 04-02-2009, 08:38 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
If you are racing/road coursing, maybe you need to swap, but I concur, stock radiator should do the job, it has for me on two builds.....
OR:FS - Misc Engine - V7 Cams / WRX Cams / WRX Rods / 2.2t Crank / 2.2t Rods mick_the_ginge Engine/Power/Exhaust 6 03-20-2007 02:17 PM
WTT: my auto 2.2T for your manual 2.2T shemoves South West Impreza Club Forum -- SWIC 1 02-27-2006 03:10 AM
where can i find info about a 2.2 to 2.2t swap? JoshP Subaru Conversions 1 08-27-2005 12:47 PM
anyone got a engine layin around? 2.5? 2.2? 2.2t? mcu81 Tri-State Area Forum 6 07-19-2002 11:36 PM
2.2t or 2.2 Adam M Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-04-2001 09:20 PM
