Welcome to the North American Subaru Impreza Owners Club Friday December 26, 2014
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 02-28-2009, 11:54 PM   #1
jemyers
Member#: 165729
Default Issues with 85 GL Wagon
I'm back. It has been a couple of years since I was active here.
Then, I was working on my 89 DL sedan. I had some timing belt issues and got those resolved. That car has been running strong ever since.
Now, I have picked up a "cream" 85 GL wagon interior and exterior in outstanding condition. Problem is engine.....
Bought the car knowing this (Family purchase).
The car is running very rough. Won't idle unless the idle set screw is set way up. Misses, runs rough. I thought it was vacum leak. Sprayed carb cleaner at the base of carb and manifold and the RPMs jumped and smoothed out. I replaced those gaskets and the vacum lines. Unfortunately no improvement.
Weird thing. I checked the timing and the book says timing should be set a 8 degrees BTDC. When I hit it with the timing light, the timing is set at past 20 degree BTDC. When I set the timing to 8 BTDC, the car starts running worse and worse.
Is it possible that when the shop that replaced the timing belts for my uncle get the job done exactly correct? My uncle says that looking back this is about the time it started running rough.
I have done all the simple checks I can think of. The local Subaru shop mechanics have no experience on early models. I need one of you guys to step up like the last time and lead me on.
Thanks in advance
jemyers is offline   Reply With Quote
Old 03-01-2009, 12:08 AM   #2
TurboneX
Member#: 21676
RX 02Foz,05OB
Yup, most likely the timing belts were done wrong.
Heres a write up on how they should be done.
http://www.ultimatesubaru.org/forum/...ad.php?t=50768
TurboneX is offline   Reply With Quote
85 GL Wagon camber problem mfolsom 'Old School' Subaru Forum 9 10-06-2006 03:35 PM
85 GL wagon needs wheels chucko66 'Old School' Subaru Forum 1 12-11-2005 01:38 AM
85 GL Wagon OffroadGL Member's Car Gallery 2 07-09-2004 11:47 AM
85 GL wagon question Lefthandblack Normally Aspirated Powertrain 3 11-17-2003 02:16 PM
('93-'01) Off Road parts for 85 GL Wagon? ImprezaRSinCT Impreza Forum 3 07-15-2002 12:32 AM
