Old 04-10-2002, 10:36 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Default Advice on washing engine
I have some spray on engine cleaner solution but if I want to hose down my engine bay, need advice on which parts do i need to plastic baggy and prevent from getting wet?
Here's a photo of my engine bay for reference. If you could point out and/or circle/photoshop that would help. Thanks
Ed
edkwon is offline   Reply With Quote
Old 04-10-2002, 11:52 AM   #2
wighti
Member#: 15345
2001 2.5RS GC6 sedan
S.T.M.
I've never done it but I've read up on it for when the time comes. So here it goes.
I've been told you only need to cover the alternator. But I would cover the fuse box and any other electrical clips.
Make sure you warm your car first. It doesn't have to be fully warmed up but warm (to brake up grease). Then use warm water. Make sure the water isn't ice cold or you'll crack your block. I'd do it during the summer cause usually the hose water is warmer or power washer water is usually warm too but I would watch how close you get because I've heard you could actually get water in your wires and cause all kinds of problems.
Hope this helps.
wighti
wighti is offline   Reply With Quote
Old 04-10-2002, 12:07 PM   #3
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
i've never done anything other than open the hood and spray it down...
I just spray it down w/ the hose and then spray some purple power on... and then wash that off with the hose
Rebellion is offline   Reply With Quote
Old 04-10-2002, 12:21 PM   #4
HudsoN456
Member#: 11462
1999 Integra GS-R
Super Sonic Blue Pearl
Can you really crack your block by spraying cold water on a warmed up engine???
HudsoN456 is offline   Reply With Quote
Old 04-10-2002, 12:35 PM   #5
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
it's possible I guess... I've done it before (without thinking about the possibility of it cracking)
Old 04-10-2002, 12:40 PM   #6
phototek60
Member#: 15470
02 WRX
But don't some people w/small high powered engines put ice on there block after a 1/4 mile run? Maybe I'm mistaken.
phototek60 is offline   Reply With Quote
Old 04-10-2002, 01:21 PM   #7
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Some people put ice in there to keep things cool... I've never seen anyone put it on the block before... Usually the intake or the intercooler, or the radiator... You CAN crack the block w/ ice cold water on a hot engine, but I think that would be more of an exception than a rule...
I don't cover anything when I wash my engine... just don't use high pressure on the hoses, wires, or any electrical connection... try to keep it out of the intake...
mrbell is offline   Reply With Quote
Old 04-10-2002, 01:54 PM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Its a good idea to go ahead and cover the alternator. As far as anything else I wouldnt worry about it, just don't spray the high pressure wash on wires and connections.
I've done that many a times and never had any problems. I just stick a bigass ziploc or grocery bag over the alternator.
trhoppe is offline   Reply With Quote
Old 04-10-2002, 02:11 PM   #9
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
looks like i'll be picking up a garden hose soon, thanks guys
Ed
Old 04-10-2002, 08:16 PM   #10
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
I use engine bright foaming cleaner on my R/C cars and my fishing reels cause it eats every piece of dirt. Any body use theses types of products on thier subes? If not, could anyone recomend some type of soaps?
moogooob is offline   Reply With Quote
Old 04-10-2002, 09:39 PM   #11
lustreking
Member#: 5154
1999 Legacy L
I recently cleaned/detailed my engine compartment using cd-2 Engine Detailing Kit or something like that... I think I have a scan somewhere. It comes in 2 cans and is a two-step dealie. The first can is the cleaner, then you use the second can which makes everything nice and shiny. I got it for about $5.00 from Target and there's at least one application left (maybe two). I think it works pretty well and have no complaints
here's a pic of the product
http://www.lustreking.com/cd2.jpg
-Steve
www.lustreking.com
lustreking is offline   Reply With Quote
Old 04-10-2002, 09:50 PM   #12
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
ooooo pretty
I guess a trip to targè is in order for me!
Thanks for the tip.
Old 04-10-2002, 10:07 PM   #13
Frederf
Member#: 15622
2002 WRX SW
Your accent is grave when it should be accoute.
Frederf is offline   Reply With Quote
Old 04-10-2002, 10:32 PM   #14
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
whats the difference?
Old 04-10-2002, 11:39 PM   #15
imposter
Member#: 10642
95 Impreza EJ22T
i've always used a powerwasher. it doesnt hurt anything as long as you keep it far enough away. i have never covered the alternator, and i have never had a problem.
imposter is offline   Reply With Quote
Old 04-11-2002, 12:35 AM   #16
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
The difference between the two accents is the pronunciation. I usually just hose down my engine bay, my engine never seems to get too dirty, so it is pretty easy to clean.
-Wes
RebelINS is offline   Reply With Quote
Old 04-11-2002, 01:04 AM   #17
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i wash mine every time i wash my car, i just spray it off i never cover anything.
jasona is offline   Reply With Quote
Old 04-11-2002, 01:19 AM   #18
LttLDGN
Member#: 5478
er... you dont have to plastic baggie anything but...
i've been told by many mechanics NOT to use pressurized water.
Most people ive talked to used green stuff or some other de-greaser and then just let a garden hose rinse it off... no pressure though.. just let it drip.. remember your whole engine gets wet anyways when you drive in rain.. just no pressurized water
LttLDGN is offline   Reply With Quote
Old 04-11-2002, 12:00 PM   #19
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
I just wipe it down with Greenstuff. Mine is never super dirty though. It helps if you garage your car.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 04-11-2002, 03:42 PM   #20
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Thanks guys i used a bottle of green stuff and hosed down my engine bay. Looks great. I did plastic baggy my alternator and Battery cover but I probably didn't need to do that since i did the washing and home and left my hood up for a couple of hours which helped to dry it off. Its not immaculate but looks a hell of a lot cleaner now.
Ed
Old 04-12-2002, 01:50 AM   #21
rayw1128
Member#: 15800
2002 impreza wrx
platinum silver
what is this green stuff u guys keep talking about???
rayw1128 is offline   Reply With Quote
Old 04-12-2002, 02:25 AM   #22
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think they mean Simple Green spray
Old 04-12-2002, 08:02 PM   #23
rayw1128
Member#: 15800
2002 impreza wrx
platinum silver
AH....Thanx
Old 04-13-2002, 12:42 AM   #24
soulcrusher500
Member#: 16328
2003 WRX
white
My brother-in-law used to detail cars and this is what he told me to do. It works very good. Take your car to DIY car wash and spray the engine with the high pressure hot water. Do not use anything but water and don't focus too much on the electrical stuff. While the engine is wet, spray the whole engine bay with Armour All, especially the plastic and rubber. Drive around and let the engine cook some of the water/armour all off. Finally, wipe the excess drips off of everything. It will shine for a couple of weeks and repell dust.
soulcrusher500 is offline   Reply With Quote
Old 04-13-2002, 04:40 AM   #25
Need4Mods
Member#: 17201
2002 WRX - Sedan
WR Blue w/JDM Rear Wiper
Feeling lazy, I didn't feel like covering any part of my engine when I went to clean it. I just popped open the hood and sprayed my engine down left to right. The engine came out nice and clean and started back up with no CELs or any problems on the sort. You shouldn't have to cover your alternator, well unless for some reason you put the nosle directly on the alternator and soak it down for some unknown reason.
Some car washes have engine degreasers, those work well to, but as far as I am concerned, nothing like H2O.
Need4Mods is offline   Reply With Quote
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-02-2010 12:32 PM
Need advice on an engine build please? scoobiekid86 Built Motor Discussion 3 02-02-2009 12:33 AM
Washed engine, Now engine light is on and wont rev past 4000RMP. renda85 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-09-2007 09:02 PM
My engine is blown, need advice on engine options GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-26-2004 06:21 PM
advice on painting engine parts jimmythagreek Bay Area Impreza Club Forum -- BAIC 4 01-07-2001 10:54 PM
