Old 03-02-2009, 09:58 PM   #1
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
Default need to flush 04 6mt what oil to use?
I need to flush the 6mt out - what cheap fluid can I use to pick up the crap, drive around for a mile or two, drain, refill and repeat?
Will end up using motul 300 after Im done flushing...
gto7419 is offline   Reply With Quote
Old 03-03-2009, 04:08 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Flushing is not necessary with a transmission, they are DESIGNED with drain and fill in mind. If you are so concerned then you'd flush with 300 to make sure you get as much of a 300 load as you can.
Old 03-03-2009, 07:40 AM   #3
gto7419
Member#: 44256
05 outback xt
No - it needs to be flushed - a bearing ate away some aluminum... I can replace the bearing, but the tranny needs to be flushed and I want to use some "cheaper" fluid...
Old 03-03-2009, 08:23 AM   #4
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***in progress***
use any fluid thats recommend for the tranny then thats cheaper than the gear 300.
penusai is offline   Reply With Quote
Old 03-03-2009, 09:16 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If that's the case, get some Coastal 99 cent gear oil.
Old 03-03-2009, 04:58 PM   #6
gto7419
Member#: 44256
05 outback xt
picked up some coastal, but its more like $3 a quart - still cheap, but I wish it was a dollar - I would have bought twice as much to flush...
need info on how to flush antifreeze and what kind to use as replacement jbsubie Service & Maintenance 6 03-25-2006 08:44 PM
Cooking ?? What oil to use to make hardshell tacos? crowbar Off-Topic 17 10-25-2004 09:42 PM
What oil to use in tranny and diff (Redline)? WRBLUEWAGON Transmission (AT/MT) & Driveline 1 06-20-2002 10:58 AM
what oil to use PHIERCE Normally Aspirated Powertrain 4 08-17-2001 05:49 PM
