Old 03-03-2009, 12:03 AM   #1
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Default Blouch 2.5 setup
Okay, so here's my whole setup. 93 and 100% meth.
Alkycontrol meth kit
Forge 100% recirc valve
Blouch 2.4in 8cm with turbo blanket
spearco tmic
aps 70mm cai
gimmick motorsports 2.4in turbo inlet
wrapped helix v3 catless dp
greddy ti catback
walbro fuel pump
Deatschwerks 740cc injectors
act street disc clutch
bc racing coilovers etc
boost oil pres egt gauge.
GM BCS
etc.
I have all the parts ordered and next week I am getting installed and tuned. I ran a 12.7 on just my stage 2 setup, which was helix catted tbe k&n typhoon fuel pump and tune. You guys think a 12.2 or so will be obtainable. Also, I am looking to have around 350whp. I will probably push 20 psi max, since this is my daily driver. You guys think I will need anything else?
I'll keep you guys posted on my setup. I might just go get it dyno'd that day too, just to see what numbers I will get and to see how my car is running.
k04sti is offline   Reply With Quote
Old 03-03-2009, 01:15 AM   #2
northmiler89
Member#: 157163
2008 STI
Silvarrrrrrrr!
dude you better run mid 11s with that setup or you suck.. in the nicest way possible.
And WTF.. you should have it on the dyno THAT DAY for a tune.. not to see how it is running.. I can tell you right now it will be running like **** and probally not at all.
northmiler89 is offline   Reply With Quote
Old 03-03-2009, 01:39 AM   #3
Mooneyes13
Member#: 113666
60' all over you
Should be interesting to see the results. Seems like the 2.5 is just a bigger 20g checking in at a 47lb turbo.
Mooneyes13 is offline   Reply With Quote
Old 03-03-2009, 02:28 AM   #4
northmiler89
Member#: 157163
2008 STI
Silvarrrrrrrr!
IIRC it is a 20g hot side with a gt30 compressor
Old 03-03-2009, 08:02 AM   #5
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
It is a hybrid like all stock locations have to be. It's a GT3071R compressor - smaller 71mm compressor wheel, specs out to 47lb/min, in a TD06 20G housing with an 8cm2. As close to a 'true' 71mm GT30R as you can get without going rotated.
Last edited by zeropsi; 03-03-2009 at 09:36 AM. Reason: D'oh! Compressor, not turbine.
zeropsi is offline   Reply With Quote
Old 03-03-2009, 08:39 AM   #6
wrxhard
Member#: 108091
Originally Posted by zer0psi View Post
It is a hybrid like all stock locations have to be. It's a GT3071R compressor - smaller 60mm turbine wheel, specs out to 47lb/min, in a TD06 20G housing with an 8cm2. As close to a 'true' 71mm GT30R as you can get without going rotated.
Fixed...
wrxhard is offline   Reply With Quote
Old 03-03-2009, 09:36 AM   #7
zeropsi
Member#: 175453
AE86 GT-S coupe
Originally Posted by wrxhard View Post
Fixed...
Ah, you got me...meant compressor wheel. Good spot! Edited the post.
That said, I mean the smaller compressor wheel: 53.1mm/71.0mm
The 60mm is the same on all 30R's...at least the Garrett ones.
Old 03-03-2009, 10:58 AM   #8
k04sti
Member#: 171773
04 wrx sti
ok...
Old 03-03-2009, 12:07 PM   #9
Five-seveN
Member#: 203275
2006 WRX SBR 20G
More boost to come!
Even with a conservative tune on that set up, you should be seeing the better half of 11s. I have a 20G 7cm and i'm looking to breaking into the 11s... YOOOU CAN DOOO EET!
Good luck though, and keep us posted. I'm anxious to see what this snail can do.
Brett
Five-seveN is offline   Reply With Quote
Old 03-03-2009, 12:40 PM   #10
Mooneyes13
Member#: 113666
60' all over you
Either way , with driver mod no problem on mid 11's!!! Looking forward to see the spool characteristics
Old 03-03-2009, 12:43 PM   #11
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
Why would say something like this?
mantra1 is offline   Reply With Quote
Old 03-03-2009, 12:44 PM   #12
northmiler89
Member#: 157163
2008 STI
Silvarrrrrrrr!
I guess I missed the part where he said they were getting installed (and tuned)
lol.. my mistake.
I was like WTFFF is someone really going to do all that and not go get it tuned!!!!
Old 03-03-2009, 12:53 PM   #13
k04sti
Member#: 171773
04 wrx sti
lol.. my mistake.
Lol of course not..
Old 03-03-2009, 01:43 PM   #14
mantra1
Member#: 23568
'08 Forester STi
lol.. my mistake.
No worries. I guess I should check my English as well
Old 03-03-2009, 03:53 PM   #15
jutes85
Member#: 127232
E90 M3
98' Foz
Okay, so here's my whole setup. No meth just pump 93.
Good luck with your set-up, mine is similiar except I have an UEL header and an EWG...waiting to be installed. Looking foward to see your results. BTW, what dyno is it getting tuned on?
jutes85 is online now   Reply With Quote
Old 03-03-2009, 05:38 PM   #16
zeropsi
Member#: 175453
AE86 GT-S coupe
Don't know about mid 11's on pump in a full weight car, but either way it'll haul.
Old 03-03-2009, 06:03 PM   #17
Mooneyes13
Member#: 113666
60' all over you
Just because you can't drive doesn't mean it can't happen. Is it a full weighter?
Old 03-03-2009, 06:33 PM   #18
k04sti
Member#: 171773
04 wrx sti
Street tune ftw. Dyno doesn't show realistic driving conditions.
I was thinking about doing a ported stock header from grimmspeed, but my numbers should be similar to yours.
Old 03-03-2009, 06:51 PM   #19
zeropsi
Member#: 175453
AE86 GT-S coupe
...yeah.
Not saying it can't, but being realistic. Full weight is an assumption.
Old 03-03-2009, 08:30 PM   #20
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
fyi on a mustang dyno with pretty much the same setup i put down 289hp/301tq on a crawford s2 block with wrx heads.
surfer5567 is offline   Reply With Quote
Old 03-03-2009, 08:53 PM   #21
k04sti
Member#: 171773
04 wrx sti
I'm sure I will be doing more than 289 no matter how low the dyno reads.
Old 03-04-2009, 01:55 AM   #22
treystoys
Member#: 97436
05 Legacy GT
white
My best run when I had the 2.5r was [email protected] in my jdm ver 8/ppg boxed wrx. I honestly think the turbo would work better with the 2.5 motor and the smaller port heads. It seemed to fall off approaching 6500 or so which should actually make it about perfect for the usdm motors. For reference, I ran the same turbo on my ej205 stock tranny same car and went [email protected] Yours may well dip into the 11s if your handy with the 6 speed.
Trey
treystoys is offline   Reply With Quote
Old 03-04-2009, 11:30 AM   #23
k04sti
Member#: 171773
04 wrx sti
Trey
Wow. I can't wait until I get this on next week. How did you like the quick spool of the turbo?
Old 03-04-2009, 03:18 PM   #24
jutes85
Member#: 127232
E90 M3
98' Foz
edit..wrong thread.
Old 03-04-2009, 10:35 PM   #25
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
keep me posted
IMPORTIMAGE is online now   Reply With Quote
Stock 2.5 RS sputters and wont accelerate STiluv55 Normally Aspirated Powertrain 3 06-04-2010 07:20 PM
blouch 2.5 04 sti k04sti Proven Power Bragging 15 05-05-2009 05:09 PM
FP Green, SZ 49, Blouch 2.5 R on Stock internals k22addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 02-21-2009 12:21 PM
vf30 and sti pink injectors - perfect for cobb 2.5 setup! anthonyrb98 Engine/Power/Exhaust 19 11-24-2006 01:54 PM
Running Higher octane on Cobb 2.5 setup? STUDAndring General Community 7 10-15-2004 09:12 AM
