Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-03-2009, 02:05 PM   #1
virjose
Member#: 57384
2004 WRX
WR Blue
Default 06-07 rear wrx rotors on 04 wrx
Hey everyone. If I go ahead and get a 2pot upgrade for my rear calipers (I have a 2004) the 06-07 rotors (they are bigger and wider) should fit my hub right? without needing to worry about the e-brake not working and stuff like when you get sti rotors in the back. Thanks in advance for the confirmation
virjose is offline   Reply With Quote
Old 03-03-2009, 02:08 PM   #2
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
Yes, you have to use adaptor brackets for the caliper, otherwise, the direct swap!
gr8r rex is offline   Reply With Quote
Old 03-03-2009, 02:10 PM   #3
06Limited
Member#: 118112
2006 WRX Limited
first: Wrong forum
Second: you will need to get caliper brackets from Turn in Concepts as the calipers won't bolt on to your backing plates. but as far as the e-brake is concerned. They are the same diameter and the rotors will fit just fine.
06Limited is offline   Reply With Quote
Old 03-03-2009, 03:32 PM   #4
virjose
Member#: 57384
2004 WRX
WR Blue
great and thanks, please close thread
06-07 rear window vaine on 05 STI deucesti Interior & Exterior Modification 3 04-19-2010 11:12 PM
06-07 wagon side skirts on 04-05 sedan overeasyeleven Interior & Exterior Modification 4 05-27-2008 12:46 AM
FS: 2004 sti rear oem rotors and 04 wrx mid pipe and downpipe.. $20 picked up NotoriousD Tri-State Area Private Classifieds 4 02-16-2008 11:18 PM
07 wrx rotors replace 04 wrx rotors? wrXiconZ Brakes, Steering & Suspension 4 02-09-2007 10:42 AM
