Old 04-11-2001, 01:04 PM   #1
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Post
42mm, 1 5/8". Unreadable while do anything other than parked and staring up close at the gauges.
Ginseng is offline   Reply With Quote
Old 04-11-2001, 01:13 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I believe you can make a new bezel for it to open it up enough to put 2-1/16" guages in it.
Old 04-11-2001, 01:19 PM   #3
DaveK
Member#: 2338
1988 323 GTX
black
Post
You have to dremel out some of the plastic so that the 2 1/16th guages will fit. (try searching for "new pics of my guage" and it should bring up some info. Joostin420 I think has the instructions.
DaveK is offline   Reply With Quote
Old 04-11-2001, 02:04 PM   #4
Jessie James
Member#: 2072
Post
Yeah, if you dremel out about 1/4" at the top and 1/8" on each side it works. I also did about 1/4" on the bottom lip so I could center the guages.
Jessie James is offline   Reply With Quote
Old 04-11-2001, 02:41 PM   #5
Jose O Perez
Member#: 341
1999 Impreza 2.5RS
Silverthorne
Post
I did this mod with Autometer 2-1/16". I had to make a bezel for the new gauges and modify the plastic housing, but nothing that a Dremel can't do. I will try to post picks of mine next week, and if you want, I can send you a CAD drawing that I make for the bezel (machined it from an aluminum plate using a CNC). I am very happy how they look, and also very functional (oil press.,A/F meter, and Volt.)
Jose O Perez is offline   Reply With Quote
Old 04-11-2001, 03:58 PM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post
Cool....I'd appreciate any help in the matter.
([email protected])
2 1/16 seems like a size I could at least see. Also...it seems like you're set-up (A/F - Volt. - Oil Pressure). Also, any ideas on a goog carbon fibre look material so it will match my trim?
I've also been looking for a way to do a DIY Suby emblem with some kind of C/F look also...no luck as of yet though.
Tats.
Tats is offline   Reply With Quote
Old 04-12-2001, 12:56 AM   #7
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post Performance Gauge Pack....again.
I did a searchand found out all I wanted to know about the Suby Perf. Ga. Pk. except one thing: What size Gauges fit in it? Standard autometer size? Which is? Thank alot and sorry for the trouble.
Tats
(Lurking for months, now finally opening his yap.)
FL: Performance Gauge Pack Boost/Volt/Oil Temp Gauges With Housing toutanje Interior/Dressup/Audio & Security 26 06-22-2008 11:58 AM
Need help anyone with performance gauge pack or oil temp gauge JDM5LugHatch Normally Aspirated Powertrain 5 06-04-2001 02:10 PM
whats on the performance gauge pack? AndyM Interior & Exterior Modification 2 05-15-2001 11:12 PM
Performance gauge pack Texas25RS Texas Impreza Club Forum -- TXIC 9 05-07-2001 06:49 AM
