Old 03-03-2009, 04:11 PM   #1
2001imprezars
Member#: 200421
2001 2.5 RS
Subaru Stars 2.5 rs turbo
im kinda new here so heres what i have 2001 impreza 2.5 rs auto just picked up everything for a stock wrx setup and just orderd a hydra ems the biggest question is i need to replace the head gasket so i was going to get head studs but will the sti head gasket or some other gasket lower my compression so i can get better numbers?? when i do the head gasket ill be swapping a 5 speed into it as well thanks for your help josh
2001imprezars is offline   Reply With Quote
Old 03-03-2009, 05:33 PM   #2
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
you can get other HG to slighty lower your compression.
Cometic is the best aftermarket replacement.
Might as well toss some better pistons in while you are donig all that.
freeride is offline   Reply With Quote
Old 03-03-2009, 06:14 PM   #3
nojokesniper
Member#: 192623
yea you can only run 5-7 psi without dropping the compression ratio, an easy way to do that is run wrx or sti rods/crank or even a 22t rod and crank setup
nojokesniper is offline   Reply With Quote
Old 03-03-2009, 08:17 PM   #4
VIsubi
Member#: 187834
06 2.5i impreza
Red
or just buy an STI block for cheap and use that instead to be relaible....more people have STI blocks then your regular WRX or EJ250 or 255...
VIsubi is offline   Reply With Quote
Old 03-03-2009, 08:18 PM   #5
2001imprezars
Member#: 200421
2001 2.5 RS
thanks for the info
Old 03-04-2009, 01:05 PM   #6
Odyknuck
Member#: 192866
2006 Impreza
How much do the HG actually lower the Compression Ratio?
Odyknuck is offline   Reply With Quote
Old 03-04-2009, 04:51 PM   #7
nojokesniper
Member#: 192623
not much , definately not enough to make a difference in the ability to run higher boost
Old 03-31-2009, 04:56 AM   #8
cloudconnects
Member#: 188777
rebuild the block with STI parts.. they can be had for cheap.
cloudconnects is offline   Reply With Quote
Old 03-31-2009, 09:38 PM   #9
freeride
Member#: 49783
SRP/white
indeed if the HG is getting redone....perfect time for new pistons!
2.5 Rs Turbo Kit!!!minnam Stage 2 Really Cheap!! subyrscanada Private 'For Sale' Classifieds 5 02-06-2005 10:41 PM
How many California 2.5 RS turbo owners? Derres Catalano Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-14-2001 12:39 AM
2.5 RS turbo killer in TRI STATE area STI VI Tri-State Area Forum 10 02-12-2001 11:39 PM
2.5 RS Turbo from an Austin dealer?! Bohanan @ work Texas Impreza Club Forum -- TXIC 5 01-03-2001 12:57 AM
What would you buy a 2.5 RS Turbo for? delectron General Forum Archive 3 10-28-2000 04:54 PM
